Need help with deltas going wrong way fast! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-23-2014, 07:18 AM Thread Starter
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 481 Post(s)
Just had cooling system flushed then oil cooler replaced. Now me deltas at 15 degrees again but the wrong way. Before my ect never got above 204 with no load. Today it's between 210 and 212 causing my fan to come on constantly and my coolant is only 199 or less. Any ideas? New thermostat too but before the flush.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #2 of 13 Old 07-23-2014, 07:19 AM Thread Starter
Anti-Hashtag Member
Quoted: 481 Post(s)
Ps I also have the super cool additive in it which is supposed to make it 5 degrees cooler.
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #3 of 13 Old 07-23-2014, 12:33 PM Thread Starter
Anti-Hashtag Member
Quoted: 481 Post(s)
Bump. Need advice
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #4 of 13 Old 07-23-2014, 05:58 PM Thread Starter
Anti-Hashtag Member
Quoted: 481 Post(s)
Last bump.
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #5 of 13 Old 07-23-2014, 07:21 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Did you use chemicals to flush it? And your post is a little confusing because all your temps are referring to ECT.
dhanna6powerstroke is offline
post #6 of 13 Old 07-23-2014, 08:04 PM
ZMANN's Avatar
Quoted: 1355 Post(s)
exactly i think he means his oil ( EOT) is lower than his ECT ??
but confused
if thats what He meant then
t stat may be an issue and i can't think of a god reason the EOT would be lower ?
the water wetter IDK what that could cause ?
We Miss you Ronnie
ZMANN is offline
post #7 of 13 Old 07-24-2014, 07:19 AM Thread Starter
Anti-Hashtag Member
Quoted: 481 Post(s)
but confused
Yes, I knew this would throw everyone for a loop. My Coolant is much higher than my oil. I did have a bad cooler, my oil was constantly over 220. Yesterday unloaded it never got over 199. But my coolant did. Stayed at 210-212 unloaded. Later that evening, I put 10k pounds behind me. I grossed at 18k #. My EOT did GREAT never getting over 204 and again staying on average around 199. My ECT however, when I stopped climed to 218 and running stayed 212-214. I saw up to 18* difference in my deltas with the load on the trailer. Could the flush have taken out my Tstat? Im lost here as to why before the flush my ECT was great and then after not???? Could I have partially killed my radiator???? This makes no sense, but my secondary fan is constantly running!
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #8 of 13 Old 07-24-2014, 07:39 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Unless you have a separate cooler, what you have described can not happen. You probably have a bad temp sensor, more than likely the coolant sensor, but I would have expected higher oil temps on a long heavy pull.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #9 of 13 Old 07-24-2014, 07:44 AM Thread Starter
Anti-Hashtag Member
Quoted: 481 Post(s)
I didnt strain my engine at all. Tow tune and ran less that 55mph the whole way. Motor didnt have to work hard at all to maintain that speed. How can I test the coolant sensor?
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #10 of 13 Old 07-24-2014, 07:59 AM
Quoted: 43 Post(s)
The easiest way is to use an IR tester right next to the probe, but to get a better result you probably will need to pull it and test it in a heated water bath with a calibrated thermometer.
You could let it sit until it is dead cold and compare the 2 temps, but that won't help if the sensor misreads at higher temperatures. Most just swap in a new sensor.
Frank
Working for Toys
