Bad turbo seal.. again?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-23-2014, 05:09 AM Thread Starter
I've scanned the forums for a long time now and stay so busy I don't ever have time anymore. So recently i pulled my turbo and replaced the bearings and seals based of prior findings of blowing white smoke only after idle when pulling out thus the burning of oil. Still blowing smoke after the replacement of the bearings and seals with only 1500ish miles on the new parts.. Could the hotside housing where the seal seats be worn out, allowing the oil to pass through?
Truck specs:
118k miles
SCT livewire w/ Gearhead and Innovative tunes
4in mbrp exhaust
k&n intake
Wicked wheel 2 (installed at the same time as bearing and seal replacement)
JMS egt probe
:edit: blue spring also.
sinister coolant filter kit.
Ill keep adding parts as I remember
-All temps (oil,coolant) are within specs staying about 3-4degrees different when finally warmed up.
-FICM 48-49V
-EGT never getting above 900
-ICP psi @580 when full operating temps reached.
A1 studs
Oil cooler
egr delete
These 3 replaced within last 2k miles.
PowertotheStoke is offline
post #2 of 4 Old 07-23-2014, 06:01 AM
ZMANN's Avatar
Quoted: 1580 Post(s)
you won't like this but i would pull the K&N first
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 07-23-2014, 06:12 AM Thread Starter
Yeah I know the k&n has bad reps on these trucks but i've not had a problem with mine and that has nothing to do with the burning of oil or smoke problem. Though I have been meaning to do the ccv mod but haven't had a chance yet.
I do plan on getting an s&b if this problem prolongs into the purchase of a new turbo but until then with proper maintenance, I'll keep the k&n
post #4 of 4 Old 07-23-2014, 04:32 PM Thread Starter
I plugged the egr valve in but left the block plate on and left the valve sitting there and no smoke..
06 XL ext-cab shortbed
-Headstuds
-EGR cooler delete
-Sinister Coolant Filter Kit w/ Napa 4070 filter
-4" MBRP straightpipe
-Wicked Wheel 2
-K&N intake
-SCT Livewire w/ SRL+ tune
-JMS egt probe
-blue spring mod
-2.5" leveling kit
-33" BFG A/T's
Yes, I did mean to make my username PowertotheStroke but I made a typo
