05 Cranks but no start - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-21-2014, 06:44 PM Thread Starter
I am working on a buddy's 05 with a crank no start complaint. It had low icp so I air tested the high pressure system and it had air coming from the oil filter housing so I thought it was the hpop. I replaced the pump and while I was in there I replaced the stand pipes, dummy plugs, icp valve, and oil cooler. Got it together and still no start I air tested it and it seemed to be leaking at the top injector oring so I replace all the orings on the injectors and the nipple cups and orings. Still the same problem now when I air test when I command the icp valve to 95% I get some air at the back of the pump but when I put 12v to it there is no air. Also the truck will start with 12v to the icp but with it plugged into the harness it only builds about 300psi. I have tried a known good ficm also and no difference. I'm really stumped I'm primarily a duramax guy so I'm learning as I go. Thanks
blackmax64 is offline
post #2 of 12 Old 07-21-2014, 07:05 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 328 Post(s)
Probably bad ipr.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 12 Old 07-22-2014, 07:26 AM Thread Starter
I'm sorry I don't know why I put icp valve I have put 2 new ipr valves in with the same result. Thanks
post #4 of 12 Old 07-22-2014, 04:18 PM
LoxDiesel's Avatar
Quoted: 328 Post(s)
Whats the ipr% while cranking?
@loxdce
post #5 of 12 Old 07-22-2014, 05:45 PM Thread Starter
The ipr is 85% and only builds around 300 psi after cranking for a while.
post #6 of 12 Old 07-22-2014, 05:56 PM
roche837's Avatar
Quoted: 5 Post(s)
Feedback Score: 4 reviews
If its only 200 psi after extended cranking then you have a HPO leak somewhere, the truck will not fire unless its above ~500 psi
Unfortunately you might have to tear down and recheck all your o rings
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #7 of 12 Old 07-22-2014, 05:58 PM
roche837's Avatar
Quoted: 5 Post(s)
I had an instance where i did a STC upgrade on a 07 and i didnt get all of the old o ring where the pump feeds the branch tubes and eventually failed again, i had to tear it apart and double check my work and found the old oring under the new one that i installed
roche837 is offline
post #8 of 12 Old 07-22-2014, 06:21 PM
roche837's Avatar
Quoted: 5 Post(s)
Did the new HPOP come with the updated STC fitting? or did you have to pull parts off the old pump? Im not familiar how they come new because i havent had to replace a pump on a 05-07 only 03-04 and they are different.
roche837 is offline
post #9 of 12 Old 07-22-2014, 06:42 PM Thread Starter
I keep going back to a leak but when I air test with shop air it doesn't leak anywhere but the back of the pump. The new pump did come with the upgraded stc fitting. The weird thing is when I have 12v to the ipr valve it will fire. Thanks
post #10 of 12 Old 07-22-2014, 06:58 PM
roche837's Avatar
Quoted: 5 Post(s)
The IPR is commanded by the FICM so if its not getting command to close this could be your problem. Check for FICM codes?
roche837 is offline
