Burning blue at cold start - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-21-2014, 08:51 AM Thread Starter
hello
New to powerstroke forums, and never owned a diesel before, but did runned it in to some issues
2007 f350 6.0 with 151000 km on it
temperature right now at night is about 10c
here is an issue
truck starts fine, doesn't shake nothing, doesn't look like its miss firing at all, have power even if engine is cold, but it will blow blue when i am moving until temperature gauge moves 1/8 and after good as new.. does smell like diesel tho.. which makes me think its a sticky injector
things i done
Checked turbo for play, seems normal to me
lil oil stains in intake but nothing leaking out of it
also truck seems to wont pick up right away from the light, if i floor it it kinda very slow till turbo kicks in and after goes like a snot. no blowing smoke, nothing at that point
any help would be appropriated
isandler is offline
post #2 of 10 Old 07-21-2014, 10:50 AM
Blue smoke is useually oil. Your turbo oil seal may leak a little wjile sitting, when you crank it up it then burns the oil in the exhaust.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 10 Old 07-21-2014, 11:06 AM Thread Starter
i thought it was.. but wouldn't it always burn blue with bad turbo seal?
isandler is offline
post #4 of 10 Old 07-21-2014, 08:25 PM Thread Starter
any one else got any idea?
isandler is offline
post #5 of 10 Old 07-22-2014, 01:16 PM
Ford diesel girl's Avatar
Quoted: 294 Post(s)
If it smells acrid, it may be fuel from an injector. I had a bluish haze on start up before I changed out all 8 injectors.
Then again, 177k miles on the original injectors may have been part of it lol.
Pinky
'04 F350 Pinky truck
BPD oil cooler system
BPD EGR cooler
BPD FICM
BPD water pump
I work at some place, in a desert, with a tank...
Originally Posted by Evil Eye View Post
Jeffrey, SHUT IT. I might have to ask Christine to give me a hand in smacking you around a little bit.
Ford diesel girl is offline
post #6 of 10 Old 07-22-2014, 01:19 PM Thread Starter
oh it definitely does smell like diesel!!
isandler is offline
post #7 of 10 Old 07-22-2014, 01:24 PM
Quoted: 294 Post(s)
It' a safe bet it is an injector or a few; how many miles on the injectors? Have you kept up with the maintenance? I had a hot no-start due to worn O-rings on the injectors, and just general age of the injectors.
I suggest starting there, but without values of ICP, IPR etc. we can't really rule anything out.
Pinky
BPD EGR cooler
BPD FICM
BPD water pump
post #8 of 10 Old 07-22-2014, 01:28 PM Thread Starter
i just got that truck 2 weeks ago, and its got 151000 km on it, i am not sure if those are original injectors or not.
i am getting sct livewire right away here, would that monitor tell me icp and ipr values? and sorry for being dumb but what are they stand for?
isandler is offline
post #9 of 10 Old 07-22-2014, 01:44 PM
Quoted: 294 Post(s)
You are not dumb at all! I am not sure that the livewire can show the ICP or IPR, to be honest; I have not used one before and am not familiar with that particular tuner from SCT.
http://www.bulletproofdiesel.tv/File...geRefGuide.pdf
^That will give you some parameters to watch/get values for, what they mean, and the values you want to see.
Pinky
BPD EGR cooler
BPD FICM
BPD water pump
post #10 of 10 Old 07-25-2014, 11:45 AM Thread Starter
soo i did oil change last night to t6 synthetic and added 2 bottles of rev-x...
it was cold this morning colder than usual about 11c and truck had no smoke at all... that **** is magic lol
but i also got weird shake now when truck is cold.. all ficm voltage is 48v and injector pressure are up to standard specs, not sure what could cause that
isandler is offline
