2006 6.0L Engine miss - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-19-2014, 07:07 AM Thread Starter
I have two ford diesels, different years, different engines, but same exact problem. My 2006 6.0 and my 2000 7.3 both miss very badly when "cold" and by cold I mean ambient temp can be 30-90 deg F. On both of them, as soon as the engine oil temp (the only temp I can watch to within a deg or two) gets to 160 it is like a switch is thrown, and they both run perfectly. When they are missing it is as bad as if they had run out of fuel and had just started picking it back up, engine/truck shakes, not enough power to hardly move. Then when the magic temperature arrives they run fine. Is there a bypass/solenoid/something that switches over when a certain temperature is made?
Thanks,
RM
Dayton TX
Rem1061 is offline
post #2 of 6 Old 07-19-2014, 07:17 AM
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 479 Post(s)
Archoil should fix you right up.
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is online now
post #3 of 6 Old 07-19-2014, 07:19 AM
Anti-Hashtag Member
Quoted: 479 Post(s)
Its called stiction. Caused by dirty oil. All 6.0's have the problem eventually. Call archoil get the 9100 and youll be amazed at the difference.
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #4 of 6 Old 07-21-2014, 09:21 AM Thread Starter
2006 6.0 miss
Ah, don't see it being a "stiction" problem, two different engines same problem, bad miss until hitting an exact (160 deg f) oil temp and then both engines smooth out perfectly. There has to be some type of automatic change that is programmed into system, ie. bypass solenoid closes, etc. Just hoped someone had knowledge of Ford diesel settings for cold engine start/warm engine run.
Thanks anyway.
Rem1061 is offline
post #5 of 6 Old 07-21-2014, 09:35 AM
Anti-Hashtag Member
Quoted: 479 Post(s)
I had the EXACT problem in my 6.0. So did 3 others of us with the motor. When I warmed up, it ran like a dream. I promise you on the 6.0 at least that is your problem. The injectors use the oil to inject the fuel. Dirty oil will cause a miss until it thins out when it gets up to temp. Mine would miss and not run right until it got warm. Then it straightened out. Someone on here told me to try the Archoil, I did and 150 miles later she was cured. The 7.3 I couldnt tell you, maybe an injector. Try it, if it works great if not your only out 30.00 and still not really as the Archoil WILL clean your engine. OH, that 30.00 will treat both motors.
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #6 of 6 Old 07-23-2014, 09:35 AM
+1 on the archoil. not saying it'll fix the problem but it doesn't hurt.
PowertotheStoke is offline
