Fuel gauge question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-19-2014, 05:44 AM Thread Starter
Fuel gauge question
When the truck is running in park sometimes the fuel gauge just drops off . Is this some kinda of warning ? The low fuel light comes on and next time I start fuel gauge back to normal.
wintford is offline
post #2 of 6 Old 07-19-2014, 01:03 PM
Nope not normal. Check the ground for corrosion, wires for chafes etc..
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 07-19-2014, 01:20 PM Thread Starter
Would the ground wiring be near the fuel tank ?
wintford is offline
post #4 of 6 Old 07-19-2014, 01:31 PM
My 2005 does the samething once in awhile.
Mostly does it when I park uphill (front up).
I need to change my sending unit. I prolly do it when I do my sump.
bgraiders323 is offline
post #5 of 6 Old 07-19-2014, 01:33 PM Thread Starter
Yep feel stupid now .
Sending unit ?
wintford is offline
post #6 of 6 Old 07-19-2014, 06:30 PM
Ok the fuel pump is on the rail the sender and float switch is in the tank.
There is aground strap under the fender in front of the rear tire unbolt and check for rust/corrosion. There is a plug inby the rear tire on the frame rail check it as well.
Follow the wire loom to the front of the truck there will be a connector there as well check it too and the wireing as well.
