Zero reading on ICP - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-18-2014, 02:56 PM Thread Starter
Zero reading on ICP
2005 E 450 (No start). Plugged in my ScanGuageII and this was my reading, ICP cranking, 20 FMP cranking 48.5, SYC cranking 1yes, IPR cranking 84.71.
Replaced ICP sensor with new pigtails and replaced IPR valve. Now IPC cranking at zero. Could it be a wire problem? Please help, mav52.
rudymav52 is offline
post #2 of 2 Old 07-18-2014, 06:29 PM
do you have updated dummy plugs and stand pipes?
you might have a low oil pressure problem
check out this other thread same issue
ZERO ICP pressure. Ran for 5 mins after repairs
bgraiders323 is offline
Tags
fmp , ipc , ipr , scanguageii
