What's the plug? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-18-2014, 01:33 PM Thread Starter
What's the plug?
Just got done with my 6.0 Excursion and swapping the headgaskets, studs, HPOP, new ICP, IPR. Basically all the good stuff.
Now the truck won't start. I thought this wiring harness was for the filter minder since it is in the same area but it won't connect.
Any ideas? And would it being disconnected cause a no-start issue? Everything else looks good, plenty of oil pressure, etc.
Thanks!
Chris
InmatesRunThePlace is offline
post #2 of 11 Old 07-18-2014, 01:35 PM
Looks like the air filter reminder
04 F550
jonesy_11950 is offline
post #3 of 11 Old 07-18-2014, 01:49 PM
Let me guess........ Is your truck a 2005???
bgraiders323 is offline
post #4 of 11 Old 07-18-2014, 04:03 PM
PowrStoked04's Avatar
Quoted: 14 Post(s)
Looks like May be a temp sensor plug
PowrStoked04 is offline
post #5 of 11 Old 07-18-2014, 04:29 PM
snowmakerdrew's Avatar
Think that's the cam sensor plug. I remember mine having that metal clip on it.
snowmakerdrew is offline
post #6 of 11 Old 07-18-2014, 04:37 PM
And the cam sensor being disconnected would cause a no start issue.
The Following User Says Thank You to snowmakerdrew For This Useful Post:
InmatesRunThePlace (07-20-2014)
post #7 of 11 Old 07-18-2014, 10:02 PM Thread Starter
That's the plug! Now it tries to start but just knocks and dies. Sometimes sputters for a few seconds before dying off. Will try again tomorrow with a fresh battery charge.
Thanks!
post #8 of 11 Old 07-20-2014, 11:18 AM
Glad to help! Did you get it running?
post #9 of 11 Old 07-20-2014, 12:07 PM Thread Starter
A bit of an update. After a battery charge I was able to get it started and running but rough.
Hooked up the scangauge and a borrowed dashboss, no DTCs and everything looked ok.
Today I hooked up my SCT programmer and it pulled up a lot of helpful DTC. Why does the SCT show error codes when the DashBoss and ScanGauge don't? Both those tools are almost worthless if they can't reliably pull up codes.
Anyway - the SCT showed both Cyl 8 injector low voltage and a Cyl 8 contribution codes. Looked a the injector harness and it wasn't plugged in. It was seated but not plugged in.
I'm going to wait until the engine cools a bit and then go plug that in. Hopefully that's it.
Thanks guys!
Chris
post #10 of 11 Old 07-20-2014, 12:18 PM
sho669's Avatar
Quoted: 4 Post(s)
You could also have an air lock in the upper fuel filter housing, that will cause it to fuel knock/die/run rough. Easy enough fix, loosen the cap, air pressure sprays fuel everywhere, put cap back on lol!
The one injector being unplugged wouldn't cause it to die, just a rough run.
-Adam
03 CCSB King Ranch 4X4 6.0, WPE Tuned, ODAWG Ported Intake, WPE R/R, WPE HD Up-Pipes, KC Stage 3, Warren 205/75's, ARP625's, Fully Rebuilt Engine w/new Ford Heads (o-ringed), Stage 1 Cam, High RPM Valvesprings, Chromoly Pushrods, No Limit CAI, Warren Full Billet 5R, SFI Billet Flexplate, 3.5" DP, 4" Exhaust, CCV Dump, Mishimoto IC, OUO Bars w/u-bolt flip and 3/4" bolts, Irate Comp Fuel System w/Fuel Lab Pump, 07 Springs and Shackles
sho669 is offline
