Yet another problem.... - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 16 Old 07-17-2014, 10:05 PM Thread Starter
mac92a2002's Avatar
Ok here we go. I have owned my 06 F350 6.0 tow boss for exactly a year. In this year she has been through 2 turbos, 2 oil coolers, a torn seal on a dummy plug and a leaking turbo oil supply tube. Now as my wife drove it home the ect's jumped to 220 with oil matching. The fan kicked in also a burning elec smell from engine compartment. No degas bottle puking but a lot of pressure in the system. This was over an hour highway drive at 65. The degas bottle is filling up not losing coolant. Due to pressure coolant is dripping slightly from lower hose (could barely squeeze the hose lower or upper. Has coolant filter and egr & egr cooler delete. Been flushed over 20 times total and switched to cat coolant. Also did complete dummy stand pipe replace with new v\cover gaskets updated drain and feed tubes for the turbo.
Did I just manage to join the blown head gasket group?
If not what are yalls thoughts.
I swear my truck was built on friday...
mac92a2002 is offline
post #2 of 16 Old 07-17-2014, 11:15 PM Thread Starter
mac92a2002's Avatar
as a follow up. The degas bottle is just getting filled more and more. Relieved the pressure in the system after warm ran more and it built little to no pressure in the upper and lower hoses. Maybe bad water pump. What would cause the coolant to get pushed back into the degas bottle almost filling it?
post #3 of 16 Old 07-18-2014, 03:34 AM
HP MACHINE's Avatar
Quoted: 157 Post(s)
Don't rule out a thermostat . They will do weird things when there going south .
Use a Ford / Motorcraft stat ONLY. Make sure the rad isn't plugging also , this will be harder to prove once it's out.
HP MACHINE is offline
The Following User Says Thank You to HP MACHINE For This Useful Post:
mac92a2002 (07-19-2014)
post #4 of 16 Old 07-18-2014, 08:56 AM
Could be silly things such as a thermostat or maybe even a bad cap thats letting the gas and coolant escape to soon.
Hopefully not a HeadGasket but ideally you would get a pressure gauge and do a test like this.
mannythechamp is offline
The Following User Says Thank You to mannythechamp For This Useful Post:
post #5 of 16 Old 07-18-2014, 10:40 AM Thread Starter
mac92a2002's Avatar
Just an update, pulled thermostat. Truck running at 169 ect 175 eot at 2000 rpm (60 mph). This after a 45 min drive, 90 degree day. Going to ford now for new thermostat. fingers crossed
post #6 of 16 Old 07-18-2014, 03:16 PM Thread Starter
mac92a2002's Avatar
Ok, well seems to have been the thermostat. I had always heard that ours stick open, but the old one seemed to have just froze closed. Oh well trip to ford to get new and done. SO HAPPY!!!! Thanks guys!!
post #7 of 16 Old 07-18-2014, 08:09 PM
glad you got that issue solved!
post #8 of 16 Old 07-19-2014, 04:53 AM
HP MACHINE's Avatar
Quoted: 157 Post(s)
Good news , now go and enjoy your truck .
post #9 of 16 Old 07-19-2014, 01:25 PM Thread Starter
mac92a2002's Avatar
Thanks guys for pointing me in the right direction!!!
post #10 of 16 Old 07-19-2014, 02:05 PM
Tennessee Powerstrokes
GoFastPadre's Avatar
The one on my dually stuck closed I wasn't as fortunate New oil cooler, t-stat and head gaskets and all is right with the world. Glad yours is fixed!
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
