Anyone know what part this is? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-17-2014, 06:34 PM Thread Starter
6pointOHHH's Avatar
So after doing a transmission flush I pulled my 04 f350 into the driveway to check the levels. After I checked the levels, the truck wouldn't start again and this part in the picture (shaped like a small L) made a loud vibration sound that wouldn't stop when the key was in the accessory position. Any ideas?
2004 F-350 CC SRW FX4 Lariat
-ARP Studs
-IPR Gen 2 EGR Delete w/up-pipe
-IPR Extreme HPOP Screen
-Wicked Wheel 2 on stock turbo
-MBRP 4" SS NC NM
-S&B CAI
-Blue Spring Upgrade
-Sinister Oil & Coolant Filter Kit
-Mag-Hytec Trans Pan and Rear Diff Cover
-Edge Insight CTS w/EGT
-Tekonsha P3
-Updated Turbo Oil Feed & Drain Tubes
-SCT SF3 w/Looney & Tow by Vivian
-Sony XAV701HD
-BedRug
-Rotella T6
-Rotella Ultra ELC Coolant
-High Idle Mod
-Diesel Turbo Lifesaver (came w/truck)
6pointOHHH is offline
post #2 of 7 Old 07-17-2014, 06:41 PM
Powerstroke Techie
justinmix's Avatar
When you say won't start to you mean it would crank but not start, or it wouldn't crank at all? The item in your pic is the vacuum pump and wouldn't have anything to do with not starting. Vacuum is only used to control the internal HVAC controls, and the automatic 4wd hubs if equipped. If it's a crank but no start condition then the recent trans service has nothing to do with it. If you have a no crank condition then it MIGHT have something to do with the trans and not seeing neutral, causing a no crank issue. Doubt this is your problem though. My guess is it's cranking fine but won't fire up. If so then it could be quite a few things. Do you have access to a scan tool or at least a code reader?
justinmix is offline
post #3 of 7 Old 07-17-2014, 06:49 PM Thread Starter
6pointOHHH's Avatar
Thanks. Yes, it cranks no problem but nothing more. The code I have ob my Insight is P0603. But, could that be caused by my running tunes?
-ARP Studs
-MBRP 4" SS NC NM
-S&B CAI
-Tekonsha P3
-Sony XAV701HD
-BedRug
-Rotella T6
-High Idle Mod
post #4 of 7 Old 07-17-2014, 06:57 PM
Powerstroke Techie
justinmix's Avatar
Yes it could, and shouldn't be causing the no start. Can you monitor ICP pressure during cranking? You need at least 500psi to start. Are the batteries in good shape and it's cranking strong? I'm guessing it's a totally unrelated issue and just something else causing the no start.
post #5 of 7 Old 07-17-2014, 07:14 PM Thread Starter
6pointOHHH's Avatar
The batteries are kind of old so I put them on a charger and then cycled through all the hard before cranking it over and it started. Hopefully, it was just those batteries. They were both reading 12.5 before charging.
-ARP Studs
-MBRP 4" SS NC NM
-S&B CAI
-Tekonsha P3
-Sony XAV701HD
-BedRug
-Rotella T6
-High Idle Mod
post #6 of 7 Old 07-17-2014, 07:17 PM
Powerstroke Techie
justinmix's Avatar
Low voltage can cause a no start issue, Even if it's still cranking semi decent. The PCM needs 9.5 volts to stay powered up, and if it's drawing to much cranking it won't power up the PCM enough to fire. I'd have the batteries load tested and make sure the terminals are clean and tight.
The Following User Says Thank You to justinmix For This Useful Post:
6pointOHHH (07-17-2014)
post #7 of 7 Old 07-17-2014, 07:50 PM Thread Starter
6pointOHHH's Avatar
Thanks for the quick help.
-ARP Studs
-MBRP 4" SS NC NM
-S&B CAI
-Tekonsha P3
-Sony XAV701HD
-BedRug
-Rotella T6
-High Idle Mod
