Oil under the Turbo/behind oil cooler - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-16-2014, 05:55 PM Thread Starter
98csvt's Avatar
Like the title says there is oil under the turbo and behind the oil cooler, I am getting new CAC boots because they have oil on them. Any input would help, thank you.
Oil under the Turbo/behind oil cooler-imageuploadedbyag-free1405558475.648666.jpgOil under the Turbo/behind oil cooler-imageuploadedbyag-free1405558495.404318.jpgOil under the Turbo/behind oil cooler-imageuploadedbyag-free1405558513.812793.jpgOil under the Turbo/behind oil cooler-imageuploadedbyag-free1405558530.274572.jpg
1998 Mustang GT
IG: whitelightning98gt
2006 F250 CCLB KR FX4 Bulletproofed, SCT Livewire TS, KC billet compressor wheel. 1.9 60' @TX2K15
1997 Mustang Cobra Track Toy
1965 2+2 Fastback Project car
Dad's Tow Vehicle: F150
Old Tow Vehicle: 06 F250 intake and tune.
98csvt is offline
post #2 of 9 Old 07-16-2014, 06:44 PM
My 6.0 looks the same, I havent taken apart but guessing the CAC boots. maybe also the turbo line.
bgraiders323 is offline
post #3 of 9 Old 07-16-2014, 07:11 PM Thread Starter
98csvt's Avatar
Ok, how hard is it to replace the turbo line?
1998 Mustang GT
98csvt is offline
post #4 of 9 Old 07-16-2014, 07:18 PM
Really easy! but you dont need to change it if its not cracked it may just need a new
o-ring.
You have the new updated one correct? The new style is the Ridge tube the old style is the steel braided line.
Also if you change the CAC boots. Make sure you do the CCV re-route.
post #5 of 9 Old 07-16-2014, 07:46 PM Thread Starter
98csvt's Avatar
Ok I will have to check that out, where is that line exactly? I do not know if it is old or new style. What is rerouting the ccv? Sorry, big time noob at most of this.
1998 Mustang GT
98csvt is offline
post #6 of 9 Old 07-16-2014, 08:05 PM
post #7 of 9 Old 07-17-2014, 04:28 AM Thread Starter
98csvt's Avatar
Wow that does look simple. I will probably do something like that. Does doing that throw a code or harm your engine? If it keeps exhaust gases and all out that's awesome lol.
1998 Mustang GT
98csvt is offline
post #8 of 9 Old 07-17-2014, 06:50 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
More than likely you have an air leak from your CAC boot connection that is allowing oily air to coat the outside of your boot and localized area. It may be possible you have a worn out CAC boot as this is fairly common. I doubt you have an oil feed gasket issue.
Without a better picture, it is also possible you may have a minor turbo seal issue where the compressor bolts to the CHRA. In any case, you really don't have much of a problem to deal with, assuming you even want to fix something.
The CCV reroute will prevent the boots from becoming saturated with oil, but it is not high on my list of "must do" projects.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #9 of 9 Old 07-17-2014, 12:53 PM Thread Starter
98csvt's Avatar
What is the CHRA?
Also what diameter clamps do I need to order with the Riff Raff CAC boots? I took a screenshot the clamps. I just have figured out I know next to nothing about diesels lol.
Oil under the Turbo/behind oil cooler-imageuploadedbyag-free1405626719.983570.jpg
Also says Turbo clamps are 2.75 and drivers side I/C is 3.25. I am just confused lol.
1998 Mustang GT
98csvt is offline
