Help with air test on HP oil system - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-16-2014, 05:17 PM Thread Starter
casper4203's Avatar
I stalled and lost ICP pressure last week. I had it towed home. The next morning it would start after fighting to get the ICP up.
After doing the air test, I replaced a few O-rings, nipple cups and dummy plugs.
When I do another air test with the valve covers off I'm hearing air from what I think may be coming from under the intake or in the crank case. I powered up the IPR and I can hear a little difference. I get a slight vapor from under coming through the valve train.
I was hoping to put my doubts as ease with the air test and not have to tear it down any further.
What are the signs of a HPOP going up?
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #2 of 6 Old 07-17-2014, 04:37 AM
Jeremy@NoLimit's Avatar
Quoted: 110 Post(s)
Is the air sound coming from the oil cooler area? If the pressure is making it back through the HPOP to the oil cooler you might be looking at a new pump. You said you installed new dummy plugs, have you updated the standpipes as well? If the stand pipe were to be leaking where it slides into the branch tube it could make the air leak sound like its coming from the pushrod/valve train area
Jeremy
2017 event info!!!!
-Jeremy- No Limit Fab
Sp@rtan, SCT, GH, PIP, H&S
Orders-1 800 581 8986
My direct line (706)549-5355
".org5" coupon code/discount for powerstroke.org members!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@NoLimit is offline
post #3 of 6 Old 07-17-2014, 05:15 AM Thread Starter
casper4203's Avatar
Jeremy
I didn't replace the standpipes. They always look perfect when I pull them. Maybe I'll try that.
I wish I could find a better way to check the HPOP without just replacing it.
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #4 of 6 Old 07-17-2014, 06:39 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
First off, if the noise is coming from the oil pan area and is loud, it is most likely the IPR is not closing completely. There should be almost no noise from any location if the system is intact. If it is closing, then you need to localize the sound better. The only noise that may seem to come from the crank area is a leak in the branch tubes or connecting points, but you should be able to localize it to those areas (back of the engine-STC or O-ring, head near stand-pipe). The pump internal failure will lead to significant gurgling from the HPOP sump which is heard easily with the oil filter cap off.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 6 Old 07-22-2014, 04:04 PM
Hi
I have been trying to fix a no start hot on my 2003 6.0 powerstroke. Anyway I see a post where you say that the hpop gurgling back to sump means HPOP is gone. \
I have a new HPOP, 6 months ago, air tested it gurgled, truck ran ok only started cold all winter, it died in mid june, refused to start no how, only had 250psi on icp during crank,
pulled it apart, airtested without the pump just using pipes, it holds pressure, but when I use the icp port or the hole on top of the pump and apply air I get gurgling through sump.
I replaced the HPOP again, tried it brand new before starting, yes it gurgles back to sump.
asked 5 ford shop foreman, no one can tell me if that is natural, one says that's normal.
so I put my truck back together, it ran great, but still won't start hot, only have 475 on icp during hot crank vs 750 on cold crank.
can you tell me how you decided that gurgling back is a failure and how I can prove it to ford to get warranty on my new HPOP?
would really appreciate ANY HELP.
THANKS
cdeclercq is offline
post #6 of 6 Old 07-22-2014, 07:07 PM
Quoted: 43 Post(s)
You are a pirate sir... but I will answer it here.
You didn't read it correctly. The gurgle in the oil filter is different than sump noise. Did you change the IPR, and can you confirm it is actually closing? Since you have already changed out the HPOP your next source of failure for and 03 is typically the IPR. Sometimes the hose connection to the rails is damaged at the quick connect or if it is screwed off, instead of using the quick connect. You may need to use a head block-off tool to help yourself. I can't really give you any more advice from distance. You need someone in person who KNOWS what to look for to help you.
Frank
Working for Toys
