bad thermostat or bad oil cooler? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-15-2014, 05:23 PM Thread Starter
soliphant's Avatar
I have a 04 with a late 04 6.0 and I noticed today while driving in various speeds on various inclines that my deltas particularily the ect is abnormal. While driving I observed various deltas between 4* and 20* differences for example at one point they were 186 & 190 and as far apart as 184 & 204 the eot seemed consistent it was the ect that kept jumping. Could the fact that it was 30*C outside have something to do with it? Im hoping its just the t-stat but I have no idea what a failing oil cooler looks like either
Scott
04 F350 Lariat Crew
CAI, EGR delete, Edge juice w/attitude, ARP's, 4 in Magnaflow turbo back, high idle, blue spring
soliphant is offline
post #2 of 7 Old 07-15-2014, 05:59 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
for a good delta test you want to get on a nice flat long road. No towing or racing just crushing at 55-60mph. You ect and eat should settle out fairly quickly and be within 15*.
Running up a hill or acceleration will quickly fowl the test.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 7 Old 07-15-2014, 06:03 PM Thread Starter
soliphant's Avatar
I will give it a shot just never seen that big of a spread except for when towing through the mountains on the other hand as well I have never seen the ect fluctuate as rapidly as it was.
Scott
04 F350 Lariat Crew
post #4 of 7 Old 07-15-2014, 06:05 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
A tstat is quick and easy thing to rule out.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 7 Old 07-15-2014, 06:07 PM Thread Starter
soliphant's Avatar
Guess I will just have to pull it and take a look
Scott
04 F350 Lariat Crew
post #6 of 7 Old 07-17-2014, 09:08 AM
EOT/ECT should never be more than 10* apart. I've never seen a failed t-stat in a 6.0 either. You can try replacing it first and seeing if it makes a difference, but I'm thinking your oil cooler is the problem. If you end up replacing your oil cooler, make sure you flush the cooling system throughly and use Ford's VC-9 iron block flush.
1FST_TA is offline
post #7 of 7 Old 07-18-2014, 10:31 AM
I put new oil cooler lately and driving my dually with heavy camper -delta would stay at 8 degrees, peaking at 11 when I kept the foot on the floor for couple of minutes taking long grades in Sierra.
You can read more details in my topic about coolant spitting.
2007 F350 dually/5000 lb, 12' tall camper.
Kajtek1 is offline
