Rough idle at start and rough while driving - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-15-2014, 09:28 AM Thread Starter
This problem just started. When I started my truck this morning I have a very rough idle and I can hear the engine making a loud "cha cha cha cha" sound (not singing sweetly to me tho). It's my daily driver and I had to go to work so I was hoping driving it would kind of work thru the problem but it didn't, as I was going down the freeway and hit about 52mph and about 1500RPM the truck shook like hell. So I hit the gas some and it smoothed out but I could still hear it. I don't know much about diesel and I'm learning as I go. If it was a gas engine I'd say I've got a miss and say it's the plug/wires but I know this doesn't have anything like that and I'm hoping it's not an injector. Would an exhaust leak or vacuum leak make it that rough or would an injector be a likely culprit? I had the FICM rebuilt at FICMrepair.com and did the 2 year warranty before they offered the lifetime. Either way any help or ideas would be appreciated.
Eevulone is offline
post #2 of 4 Old 07-15-2014, 09:36 AM
Ford diesel girl's Avatar
Quoted: 292 Post(s)
Have you hooked it up to a data monitor? A lot of symptoms can look like a lot of things; without values, it is hard to help.
Get a scanner on there, read FICM power, ICP, IPR, etc. Do an injector buzz/contribution test and the like. Once you do that, we can take the results and determine a better plan of action.
Pinky
'04 F350 Pinky truck
I work at some place, in a desert, with a tank...
Originally Posted by Evil Eye View Post
Jeffrey, SHUT IT. I might have to ask Christine to give me a hand in smacking you around a little bit.
Ford diesel girl is offline
post #3 of 4 Old 07-19-2014, 11:02 AM Thread Starter
Took it to a buddy at a Ford store, said #2 injector was gone. Had a feeling but I can't be without my truck so I'm having him replace it.
Eevulone is offline
post #4 of 4 Old 07-22-2014, 01:50 PM
Quoted: 292 Post(s)
It is highly recommended to replace all 4 injectors on one side if one goes; all 8 if possible.
Pinky
