engine stalled and I have a 2285 code - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-12-2014, 03:40 AM Thread Starter
casper4203's Avatar
OK guys. Need a refresher course on ICP.
Just got back from a camping trip last week. Truck ran great as it has since last year when I tore into her. I went to start it up and it did the long cranking as I watched the ICP pressure slowly build before it started. I thought another internal oil leak.
Last night I was turning into a lot full of new Dodges and it stalls. On the way it did the surge thing once or twice. I pulled a 2285 code (low icp voltage).
I have a 2005. Is my ICP the one behind the turbo? What's the sensor on the right side valve cover (again)?
Thanks,
Casper
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #2 of 8 Old 07-12-2014, 06:35 AM Thread Starter
casper4203's Avatar
Well I cleared the codes. It started but it cranked a lot longer than normal.
Next I pulled the oil breather and cap. Put my adapter in the ICP port and pressure tested. I heard the gurgling down low but no air.
I guess I'm gonna try replacing the ICP and the IPR
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #3 of 8 Old 07-12-2014, 07:12 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Just leave the ICP unplugged and see if your psi numbers come up and starts quick. If it does, then most likely it's just the ICP
dhanna6powerstroke is offline
post #4 of 8 Old 07-12-2014, 09:29 AM Thread Starter
casper4203's Avatar
I did that last night. It used the default pressure but still would not start.
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #5 of 8 Old 07-12-2014, 09:38 AM
Mod Newbie
Quoted: 20 Post(s)
When you pressure checked it, did you have a way to close the IPR?
post #6 of 8 Old 07-13-2014, 04:42 AM Thread Starter
casper4203's Avatar
No, I did not
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
post #7 of 8 Old 07-13-2014, 02:41 PM
Mod Newbie
Quoted: 20 Post(s)
Originally Posted by casper4203 View Post
No, I did not
Unless you close the IPR, you can't verify where the leak is.
post #8 of 8 Old 07-13-2014, 03:11 PM Thread Starter
casper4203's Avatar
Yeah. I pulled the turbo and jump started the IPR. It showed me that my 11 month old dumby plug was leaking.
The sweeper was chewed up. I guess that would make it fail
It said made in China which I didn't catch when I put it in. I'm gonna try a dealer replacement
Rich
EGR Delete
2005 Lariat CC/SB
Banks Ram-Air
Firetone Air-Bags
and Pyro
