No Start - all 8 injector circuits high - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-09-2014, 10:24 AM Thread Starter
akl
Hey all, I just bought a non running 05 F350 as a project but I'm quickly thinking I got in over my head as I'm totally new to the powerstrokes! Help would be greatly appreciated!
I've been using the torque app to read sensors/codes and this is where I'm at. FICM had been replaced by previous owner, showing 48v. I'm also showing about 1600psi on the HPOP when cranking. When I scanned the codes I found all 8 injector circuits are "high", code P0262, etc., indicating a short???
What should I be looking for? I checked for broken wires leading into the FICM and everything looked good. Could it be all 8 injectors are bad? I also noticed the wheel well cover was missing right on the driver side, electronics had some dirt in there but I cleaned them out pretty good and still not starting. Thanks in advance!
akl is offline
post #2 of 3 Old 07-09-2014, 11:14 AM
COONASS
WHAT HAPPENED's Avatar
Check out my sig it has the manuals and more....
Injectors
-PCM at the latest calibration?
Bad injectors can cause a surge, hard start, cold rough run, low power, black smoke or a miss. Address oil and fuel maintenance issues and aeration before replacing injectors.
-Injector installation is critical, improper torque will cause injector chamber gasket failures.
-Injector chamber gasket failures will result in aeration in the fuel from combustion gases.
-Failure to remove the oil from the hold down bolt hole will result in improper torque.
-Broken injector stator housings, when the two bolts that holds the stator housing to the injector body break, are caused by air in the fuel.
-2004 1/4 vehicles need to update the stand pipes when replacing injectors.
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
post #3 of 3 Old 07-09-2014, 12:57 PM Thread Starter
akl
Thanks for the advice. Would it be possible that the replacement FICM didn't get programmed? How can I tell if that hasn't been done? It's a rebuilt unit from Alliant Power.
akl is offline
