Buddy's '06 problems - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2014, 08:33 PM Thread Starter
Friend of mine has been having problems with his '06. Initially it was puking coolant from his degas bottle, so he opted for a EGR delete. After it was installed, he had some serious oil losses thus taking it back to a different shop. At shop #2 he had a new OEM oil cooler installed. Now his truck is still losing coolant from degas bottle and he's blowing white smoke upon acceleration from the dead stop. Doesn't last too long, but it happens every time. I'm at a loss as to the problem. Mechanic #2 says it could be fuel problems, but wouldn't the smoke be black if it were over fueling? The head bolts/gaskets are the original ones and he's been running an SCT with mild tune (+50 hp). What gives?
Tellicorick
____________________
2006 PSD, CC, FX4, Lariat
Bullet Proof Diesel Full Mod
ARP Bolts
Mildly shaved heads
Elite Sneaky Up-pipe
SCT X3 Tunes by ID
MagnaFlow Exhaust
XDP Coolant Filter
Bilstein 5100 series shocks
Stock suspension w/ leveling kit
Transfer flow 42 gallon tank
tellicorick is offline
post #2 of 7 Old 07-07-2014, 09:07 PM
fr9090's Avatar
Quoted: 4 Post(s)
Head gaskets
fr9090 is offline
post #3 of 7 Old 07-07-2014, 09:40 PM Thread Starter
Yeah, that's what I was thinking as well. Bud just doesn't want to hear this news, but he needs to hear it. I asked him to strongly consider the full route when he did the cat delete but he didn't want to lay out that much money. Now he's already a couple of thou into it and will have to basically re-do what's already been done, so to speak.
I appreciate it.
Tellicorick
ARP Bolts
Mildly shaved heads
SCT X3 Tunes by ID
MagnaFlow Exhaust
XDP Coolant Filter
post #4 of 7 Old 07-07-2014, 09:45 PM
fr9090's Avatar
Quoted: 4 Post(s)
No prob. I'm dealing with mine possibly starting to leak. No where near what ur friend is experiencing but u never want to hear it. I want to do mine myself but won't have time or space in shop till winter. but if It fails the pressure test tomo I have to for the first time trust someone else to take care of my stuff.... Which I hate. Anyway good luck
fr9090 is offline
post #5 of 7 Old 07-08-2014, 07:24 AM
fr9090's Avatar
Quoted: 4 Post(s)
Wait is his egr cooler deleted? If not replace that first. Then run test on head gaskets. Sorry I thought I read he replaced that already
fr9090 is offline
post #6 of 7 Old 07-08-2014, 09:51 AM
Why did shop to install a new oil cooler? The only way oil can escape an oil cooler is via it rupturing into the coolant system.
White smoke is generally EGR related but since you said he deleted that my next guess would be fuel related. Is there any codes?
I would try putting it on stock (no tune) and see if that makes it better or worse.
I would also install a PSI gauge on the coolant system before calling it headgaskets. And make sure you are filling it to the correct fill line. And verify your coolant is clean and of the proper mix ration, and your degas cap is updated....there are so many 'ands'
Seattle60 is offline
post #7 of 7 Old 07-08-2014, 01:39 PM Thread Starter
Yes, the first shop stop was to delete the EGR cooler. The second shop flushed his cooling system and installed a new cooler - which I believe he told me was a Ford part.
One thing I missed, and he told me today, was after the second shop installed the cooler, the mechanic took the truck out and got into it pretty hard. It was after this he began to see the white exhaust.
Tellicorick
ARP Bolts
Mildly shaved heads
SCT X3 Tunes by ID
MagnaFlow Exhaust
XDP Coolant Filter
