Turbo Oil Supply leaking badly at STC fitting - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-07-2014, 06:44 PM Thread Starter
Thenewguy1118's Avatar
Location: http://www.zeemaps.com/view?group=179138&x=-93.606516&y=41.641670&z=6
Just did EGR delete, oil cooler, 6.4 banjo bolts, and a few other things. Truck fired up just fine but is pumping oil out of the turbo supply line. Leaked out 5qts in the first test drive after I had it running again. Could the line be bad or does it just need reinstalled? I tapped it down into the fitting and it only seemed to leak worse.
Thenewguy1118 is offline
post #2 of 2 Old 07-07-2014, 06:50 PM
I didnt even realize it came apart without unscrewing it. I took mine apart but ended up getting a new oil cooler cover top portion and installing the updated oil cooler line.
Not much help but thats probably where your headed if it is borked because I dont know if they sell the old line.
2003 F350 Lariat 6.0L
MTW stage 1, 4" MBRP, IPR coolant filter, 05 front cover and water pump, everything else pretty much stock.
Quint is offline
