Fuel pressure/boost.....so lost :( - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-05-2014, 10:58 AM Thread Starter
jme__gt's Avatar
Quoted: 8 Post(s)
Garage
Unhappy Fuel pressure/boost.....so lost :(
So about a month and a half ago i decided to install my fuel pressure gauge and blue spring mod. I also put in a s&b intake. So once i finished up installing but the fuel psi was about 61-62 at idle but as im leaving the drive way it wouldnt boost more than 8psi.
I have a edge and put it to 0 to make sure it wasnt a tuning issue but still after some driving it would boost over 14lbs. I then for some work for a few weeks and yesterday i had gotten my new fuel filters(motorcraft) and decided ill do them one at a time. Replaced the upper one and then psi was right at 60-62! Thought hell yea! Drove around about 5-10 miles but still boost now still wont go over 17psi. I used to easily hit 25ish even in stock. Now i also recently installed a new egr valve. Had it unplugged for about 3k miles. So i though maybe thats why the boost is low? So i stop get out shut off the truck and unplug it...fire her back up and fuel psi just goes to 40-42....f*ck. get her home with still not being able to boost like before and then i decided lets pull the top filter again. Pull it and put it back psi goes back to 60! Let it idle and one more drive around. Call it a day. Next morning i get it and start it, back to 40 so i do the filter on the lower end and same same result. 60 at first and start it a couple hours later boom back to 40 all with the same sad boost levels. I dont think there is a boost leak i only removed the piping that goes into the egr and i put that on pretty tight. And the intake before input the s&b was afe progaurd magnum. If anybody has any idea what this could be please feel free to chime in!! Im thinking that the low fuel pressure might be affecting the boost. And yes there is loss of power. But i dont know whats up the fuel psi unfortunately i didnt test before the spring oh and the fuel gauge is a isspro evoII i used the strictly diesel hose out of the bowl test fitting and routes to the driver side firewall to the transducer
2003 F-350 XLT, 6.0 P/S, BPD Oil cooler w/filter(& Thermostat, BPD EGR cooler, BPD FICM(58vlts), BPD water pump, DD R/R Kit, ARPs, WW2, Kitty Delete, fuel/boost/trans/pyro, Scan Gauge II, ZF6 SWAPPED with Valair DD, Full Traction Coilover kit 5" with Kings Shocks, 35" BFG
8.981 ET 74.25MPH 1/8th(with the Auto)
jme__gt is offline
post #2 of 14 Old 07-06-2014, 07:06 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Did you check the CAC boots for damage, especially the 45* boot coming off the turbo, you may have to pull the boot off to inspect, sometimes the damage can be right under the clamp. Check the Map hose for damage and remove hose to clean out hose and fitting that goes in the intake. Check your EBP sensor for plug/wire damage, clean out EBP tubing going from sensor to manifold. Cracked or damaged y-pipe/up-pipe flex joints (bellows) can cause low boost. Could also be sticking VGT vanes from a dirty/rusty unison ring and vanes.
Being that you didn't have a fuel gauge on before, your low fuel psi might have been their prior. Might be weak HFCM, air entering fuel lines, or restriction of fuel line in tank.
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 14 Old 07-06-2014, 11:55 AM Thread Starter
jme__gt's Avatar
Quoted: 8 Post(s)
Garage
I have the scan gauge and it cycles what seems to be fine. And the truck doesnt have a map sensor it has the maf. I think the later 6.0 had just the map sensor. I need to get a turbo piping diagram so i can locate all of that. J
jme__gt is offline
post #4 of 14 Old 07-09-2014, 09:11 PM Thread Starter
jme__gt's Avatar
Quoted: 8 Post(s)
Garage
UPDATE!!!
Update: found missing oring in regulator that goes in before the black poppet...been holding steady 60-62 psi for the past 4 days so it should be good!
still have low boost been monitoring the vgt cycle and boost. lowest it will drop is to 42-45 on vgt and wont make more that 17psi.
could this be a dirty maf issue or ebp? how would those being damaged or not working mess with the turbo? not questioning but just curious for knowledge ill check them tomorrow after work. would it be obvious if they were damaged or somthing wrong with them? im not getting any cels
jme__gt is offline
post #5 of 14 Old 07-10-2014, 03:23 AM
Powerstroke Techie
Lilpooh's Avatar
Cool, fuel psi solved.
MAP & EBP inputs are what the PCM uses to control VGT duty cycle as well as Acelerator pedal position and a few other things. But when those sensors get dirty or go bad the turbo dont act right.
Monitor MAP & EBP & BARO they need to be within .5psi at KOEO.
Lilpooh is offline
post #6 of 14 Old 07-10-2014, 08:43 AM Thread Starter
jme__gt's Avatar
Quoted: 8 Post(s)
Garage
I think im going to have to enter those pids into my scan gauge2 i have the pre loaded one from BPD so they might not be on there but ill give then a call or find out how to enter them
Anyone know a where i can find the pids?
jme__gt is offline
post #7 of 14 Old 07-10-2014, 11:43 AM
Powerstroke Techie
Lilpooh's Avatar
Post #51 in the link below was a formula list for ScangaugeII.
Write Up: Monitoring the 6.0L PSD.
Lilpooh is offline
post #8 of 14 Old 07-10-2014, 02:18 PM Thread Starter
jme__gt's Avatar
Quoted: 8 Post(s)
Garage
So i entered the pids. Map is 14.3 and Bar is 14.2-3
Also try to enter ebp but apparently my year truck was flashed to no longer use the ebp sensor. Its pretty much a dud.
Now my question is for the pid reading on the vgt. Is that desired or actual vane percentage?
I watched my friends 06 6.0 and at wot ive seen his vgt drop to mid 30s and boost around 24-28psi. My vgt lowest was 42-45 ish and nothing more than 17psi. So is it trying to open or maybe its not even getting the command?
jme__gt is offline
post #9 of 14 Old 07-10-2014, 02:26 PM
Teachagmech's Avatar
Quoted: 408 Post(s)
Garage
you may have a dirty turbo too. not sure why it would act up all of a sudden, but stranger things have happened.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #10 of 14 Old 07-10-2014, 02:30 PM Thread Starter
jme__gt's Avatar
Quoted: 8 Post(s)
Garage
Yea thats kinda what im thinking too. Its weirs because it was just fine before i did the s&b intake and blue spring mod.
jme__gt is offline
