Makes 350 PSI with the IPR unplugged - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-05-2014, 10:28 AM Thread Starter
Hey guys, my truck is making 350 PSI when the IPR is unplugged and well over 3000 when is is plugged in. I have a high pressure gauge hooked up to the ICP to monitor this. When the IPR is plugged in and it makes the 3000+ PSI the truck does not start. Any ideas on what's causing this?
vashaman01 is offline
post #2 of 9 Old 07-05-2014, 10:37 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Feedback Score: 4 reviews
Can we get a little more background on this? Does it start when your IPR isn't hooked up?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 9 Old 07-05-2014, 12:12 PM Thread Starter
The truck initially had a stall when hot. This was a problem that I could not figure out since there weren't any leaks in the HPO system. I tested it with the air test through the IPR and by doing a high pressure test by hooking up a gauge to the ICP while the truck is running. Now it won't start and pressure builds to 3000+ PSI while cranking with the IPR plugged in and builds 350 PSI with it unplugged.
post #4 of 9 Old 07-05-2014, 01:42 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Sounds like a bad ICP based only on your readings. It should show 500psi unplugged. What year is your truck?
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #5 of 9 Old 07-05-2014, 02:04 PM Thread Starter
I'm monitoring the pressure using a high pressure gauge that's in place of the ICP. So I'm getting actual readings. The gauge goes up to 3000 PSI and with IPR connected it actually goes to 4000+. Can't really tell because it's maxing out the gauge.
post #6 of 9 Old 07-05-2014, 03:48 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
sounds like your hpop is making plenty of pressure and not leaking out of the high pressure oil system.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #7 of 9 Old 07-05-2014, 08:02 PM
Are you makeing sync? Sounds like your oil system is ok but not shure getting your readings from the icp port with a gauge and useing the ipr that way.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 9 Old 07-06-2014, 09:05 AM Thread Starter
Sync is for the camshaft and crankshaft sensors, it has very little to do with this situation. By unhooking the ICP it will just default the IPR to be open at 32% if I remember correctly. Still the engine should not develop 3000-4000 or more PSI while cranking, you only need 450 to start. I think a normal system will develop 900 max at crank and idle at 600.
post #9 of 9 Old 07-06-2014, 08:57 PM
sho669's Avatar
Quoted: 4 Post(s)
A normal system will develop 3000 psi after the IPR is fully closed while cranking.
Check DTC's, check Sync, check fuel, run a buzz test. You seem to have plenty of ICP.
-Adam
03 CCSB King Ranch 4X4 6.0, WPE Tuned, ODAWG Ported Intake, WPE R/R, WPE HD Up-Pipes, KC Stage 3, Warren 205/75's, ARP625's, Fully Rebuilt Engine w/new Ford Heads (o-ringed), Stage 1 Cam, High RPM Valvesprings, Chromoly Pushrods, No Limit CAI, Warren Full Billet 5R, SFI Billet Flexplate, 3.5" DP, 4" Exhaust, CCV Dump, Mishimoto IC, OUO Bars w/u-bolt flip and 3/4" bolts, Irate Comp Fuel System w/Fuel Lab Pump, 07 Springs and Shackles
sho669 is offline
