Cylinder Head Issue - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-03-2014, 03:44 PM Thread Starter
FORD4LIFE
powerstrokeculver's Avatar
Quoted: 2 Post(s)
Exclamation Cylinder Head Issue
So the time finally came for me to do my head studs. I found a shop in town that works on many powerstrokes. They are also a BPD preferred installer. So I knew they knew what they were doing. Had my heads off and to the machine shop in a day. Well this is where the problem started. The rest of this is what i was told..... When my heads were checked and fluxed they found some issues. First being that my heads are warped and need to be decked three thousands. From my understanding this is not the end of the world and is common. Also well within the max allowed to take off. OK, I can live with that. Next problems were cracks.
From the mouth of the lead service tech "The shop found some cracks near the valves. They put the heads under a coolant flow test and bumped it up to 40psi. Most shops only do up to 30psi but they wanted to make sure your heads were good. At 40psi, no leaks. This is way over what your stock system will produce. so you might be ok. With the ARP studs you might get away with it. However when the coolant reaches 200+, it may or may not expand them and leak." They had not heard from the machine shop if they were surface cracks or cracks that run deep.
I would first like to state that I really don't have the money for new heads. Which is why I am looking for the advice of the forum members. Will I be good with just having them deck the heads? Will it all hold up with the set up I have now? ie. intake, daily tune from DP-tuner, 4" straight pipe, 53v FICM from BPD. I plan on upgrading the turbo and injectors way down the road. Nothing super mean. I want to keep the towing capabilities of the truck. At most a stage 2 turbo and 175cc injectors. And like I said, this is down the line.
What are some of the questions I should be asking my shop? Like as far as their opinions on what I should do. What are some of the down sides of running with cracks around the valves? What should I do. Any and all input is appreciated. Thank you guys.
Work Horse
2006 F250 FX4
6'' Lift Donahoe Racing
Toyo ATII's 35x12.5R18 on Moto Metel Black
BPD Engine Oil Cooler
BPD FICM 53V
K&N CAI
4" Straight Pipe
XDP Coolant Filter Kit
Blue Spring mod
SCT Tuned by DP-Tuning
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
155cc or 175cc Injectors
Stage 1 or 2 Turbo
BPD Water Pump
powerstrokeculver is offline
post #2 of 8 Old 07-03-2014, 06:12 PM Thread Starter
FORD4LIFE
Quoted: 2 Post(s)
Also..
I would also like to add that prior to all of this my coolant would only leak during WOT. It would never eat coolant. Only puke it out of the bottle. And once it was drained to just above the bottom hoses it wouldn't puke at all. Most likely due to the low level.
Work Horse
2006 F250 FX4
BPD FICM 53V
K&N CAI
4" Straight Pipe
Blue Spring mod
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
Stage 1 or 2 Turbo
BPD Water Pump
post #3 of 8 Old 07-03-2014, 06:27 PM
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
I had $1000 into doing my heads, decked, magna fluxed, new valve seals and valve guides. I think a new set from clear water is around $1600. Just food for thought......
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #4 of 8 Old 07-07-2014, 04:46 AM
I'm preparing for heads myself and given everyone else misfortune, I just picked up a set of heads from Clearwater before even tearing into the truck. It's my daily driver so I can't afford for it to be down too long and having new heads waiting while I tear it down makes me feel better. I just picked up a set of heads for my 03 MY engine for $1200 shipped to my house. I'm sure shipping will be different from state to state, but $1200 for heads and shipping from FL to OH seems well worth it to me.
jkbailmeout is offline
post #5 of 8 Old 07-07-2014, 08:44 AM
jmeaby's Avatar
Quoted: 16 Post(s)
i thought clear water was selling those crap heads? not sure just double check make sure they are ok
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #6 of 8 Old 07-07-2014, 09:02 AM
god i hope not. I've seen so many posts about other guys using their heads, now you got me concerned.
2004 Excursion
post #7 of 8 Old 07-07-2014, 11:01 AM Thread Starter
FORD4LIFE
Quoted: 2 Post(s)
I see your point. But I've read one to many bad reviews on those heads to make me want to shell over money to them. I talked to my shop today and they got word back from the machine shop. They said my cracks are not that bad. Mostly on the exhaust side. I just need my heads to hold up until I can do a complete tear down and build down the line. I don't plan on pushing lots of power until I have o-ringed heads on my truck. The next time I do this, I'll have a lift and just do it myself. That's the main reason I didn't do it myself. I was not about to pull my front end apart in the 100+ Vegas heat.
Work Horse
2006 F250 FX4
BPD FICM 53V
K&N CAI
4" Straight Pipe
Blue Spring mod
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
Stage 1 or 2 Turbo
BPD Water Pump
post #8 of 8 Old 07-07-2014, 12:58 PM
well suck me sideways. now that I dig a little more into it even some of the guys that posted they used them hated their decision later. I made good use of my time at work today. Now to figure out how to avoid the restock fee. They told me it was a reman head and not a chinatown cast. Guess I'll find out tomorrow when it comes.
2004 Excursion
