Stranded roadside need help ASAP! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-02-2014, 08:19 PM Thread Starter
Deer Creek's Avatar
Quoted: 51 Post(s)
Headed home tonight and she stalled out on me. I know the routine with unplugging the ICP to get it to fire off, BUT I'm sitting on the side of the road and need to know what's the best way to unplug it road side? Keep in mind she's an early 04 with the ICP behind the turbo. Any help would be greatly appreciated!
Sent from AutoGuide.com App
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT Livewire Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #2 of 8 Old 07-02-2014, 08:29 PM Thread Starter
Deer Creek's Avatar
Quoted: 51 Post(s)
Any body online that could give me some insight?
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT Livewire Tuner
post #3 of 8 Old 07-02-2014, 08:30 PM Thread Starter
Deer Creek's Avatar
Quoted: 51 Post(s)
Like I said I'm sitting here on the side of the road. Thanks in advance.
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT Livewire Tuner
post #4 of 8 Old 07-02-2014, 08:34 PM Thread Starter
Deer Creek's Avatar
Quoted: 51 Post(s)
She turns over fast just not firing. My SCT live wire read a P2623 Fuel Injection Control circuit open. Any idea how I can fix enough to limp home.
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT Livewire Tuner
post #5 of 8 Old 07-02-2014, 08:46 PM Thread Starter
Deer Creek's Avatar
Quoted: 51 Post(s)
Anybody?
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT Livewire Tuner
post #6 of 8 Old 07-02-2014, 09:05 PM
I am not sure how to unplug that guy with everything in there. I had a hard enough time plugging mine back in with the ficm and intake hoses out.
Ofcourse if you were down to the wire you could always cut the pig tail with some long nippers maybe and see if that would get it going.
Quint is offline
post #7 of 8 Old 07-02-2014, 10:07 PM
Mexfdmnb's Avatar
I have an 05 so I got the easy ICP sensor I don't think your going to be able to reach yours but sounds like IPR valve got stuck how much ICP are you reading when cranking?
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #8 of 8 Old 07-03-2014, 01:59 PM
I think you need to check your ficm plugs are seated in properly. This is probably too late to help. Hope you finally got off the side of the road.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
