6.0 Not Working Great!! - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By SargentoPistola
post #1 of 7 Old 07-02-2014, 03:53 PM Thread Starter
Jeff-F350's Avatar
Quoted: 14 Post(s)
OK, OK... lets here it....
Tick tock, has tocked... for those that followed the 6.0 working great thread!
No Start. Tach not moving either. I havent had the time yet to look into it any further. sounds to me like the engine is de-fueling - (as in something is telling it not to start). turn over fast. have not checked anything else yet.
Has been working fine until an hour ago. all parameters have been fine. shut it down - tried to start it 15 minutes later - no go.
I can not remember if the tach moves during the start cycle or not.. it might not now that i think about it..
video here to listen.
https://www.youtube.com/watch?v=Tkxy...ature=youtu.be
Any suggestions welcome. Thanks. going to be looking into it tomorrow morning.
~ Support them
2010 F350 CCSB SRW
Cabela's edition
2004 F350 SCSB SRW
Deleted
Sinister Coolant Filter
Everything else stock.
Original head bolts
1996 F250 RCLB
Plow Truck
Jeff-F350 is offline
post #2 of 7 Old 07-02-2014, 04:02 PM
SargentoPistola's Avatar
Say it ain't so!
What is your oil PSI on startup? What do you have to monitor the truck? I guess if it were me I'd check to see if the pump is pushing fuel into the top filter. Can you hear the injectors buzz? Can you hear the fuel pump?
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
The Following User Says Thank You to SargentoPistola For This Useful Post:
Jeff-F350 (07-02-2014)
post #3 of 7 Old 07-02-2014, 05:38 PM Thread Starter
Jeff-F350's Avatar
Quoted: 14 Post(s)
Originally Posted by SargentoPistola View Post
Say it ain't so!
Well... surprised only you chimmed in Pistola!
too make a long story short... it is running and running very well.
here is another video.. can anyone guess what the cause of this was?
A hint - very embarrasing for me..think ill just go drowned in a few beer now. and not out of fuel..
https://www.youtube.com/watch?v=H6tN...ature=youtu.be
..... I pulled the emergency stop by accident and didnt know it. it has to be manually reset.....
Alls well that ends well.
Miller Time.
~ Support them
2010 F350 CCSB SRW
Cabela's edition
2004 F350 SCSB SRW
Deleted
Original head bolts
1996 F250 RCLB
Plow Truck
post #4 of 7 Old 07-02-2014, 06:29 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
What???? You did what??????
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 7 Old 07-02-2014, 07:02 PM
Miller isn't beer. Miller is what they give children to hydrate themselves after severe bouts with an illness. Despite your poor taste in alcoholic beverages I'm glad you figured it out and it was free, well besides what it cost your ego.
Jeff-F350 and Heavy_GD like this.
-Kyle-
SCT w/ MPD
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
post #6 of 7 Old 07-02-2014, 08:23 PM Thread Starter
Jeff-F350's Avatar
Quoted: 14 Post(s)
Everyone seems to look at me sideways when I tell them what happened....
Emergency shut down:
It is a spring loaded and actuated butterfly valve in the air intake, with a mechanical actuator on the intake pipe. The pull handle to engage it is right beside the drivers seat. I'll take a picture a post it. Shuts down the intake in case of a runaway - in particular for use out in oil and gas fields, or around an area with fumes.
It is the first time I engaged it. I didn't know I had. Took me a while to figure that out! It is manually reset by hand. It had the strangest effect. IMO, It created a vacuum in the intake and cyls, and the engine would really rev up fast.
I'm a little worried about how much fuel I put in the oil. Change it out in the morning.
No worries on the Miller piss. I'm onto Keith's Red. An east coasters beer. IPA.
I will take pictures tomorrow and post them in a thread.
~ Support them
2010 F350 CCSB SRW
Cabela's edition
2004 F350 SCSB SRW
Deleted
Original head bolts
1996 F250 RCLB
Plow Truck
post #7 of 7 Old 07-03-2014, 07:01 AM
I remember those well. Had to install them for awhile on every portable engine that would go into a plant and big trucks.
Never knew of anyone installing one on a 6.0 before. If it was a 05 had to be a external add on device. 05 and later had no flapper.valve in the intake.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
