engine from hell - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-01-2014, 10:26 AM Thread Starter
engine from hell
I have an 03 F-250 6.0 and have been trying to fix it for 3 weeks now.
First started off blowing black smoke,
changed all the fluids and filters, no help
took it to the shop, 4 and 8 injectors were gone,
replaced those,
still blowing smoke, but a white smoke now,
brought it back in,
said the turbo was leaking.
bought and installed brand new Garrett turbo.
blowing blue smoke now only when accelerating, and running rough at idle
had an exhaust leak so replaced the manifold gaskets
still blowing blue smoke now only when accelerating, and running rough at idle,
Took it to ford, they said it was the FICM
they replaced that and said the 1 and 8 injector had low compression, and it was something internal in the motor causing it to blow blue smoke and run rough
after spending over 4000 dollars on allllll of that i reallllly dont want to pay ford to go through it, so my boyfriends taking the motor apart and noticed the high pressure oil rail is leaking, could that cause it to run rough on idle and blow blue smoke?
or any other ideas what internally could cause this?
any advice is appreciated!!!
thank you in advance
livvgalanti is offline
post #2 of 6 Old 07-01-2014, 10:44 AM
Berto's Avatar
Had a buddy same truck very similar problems had it for 4 months dropped 6 Grand in it and sold it still running like complete ****. It seems like a trend with the early 6.0s
Berto is offline
post #3 of 6 Old 07-01-2014, 10:54 AM
Heavy_GD's Avatar
Quoted: 1438 Post(s)
Feedback Score: 3 reviews
Do you have a monitor?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #4 of 6 Old 07-01-2014, 10:56 AM Thread Starter
unfortunately not
post #5 of 6 Old 07-01-2014, 10:59 AM
Would you be able to elaborate on this more? I'm not sure how a turbo could "leak". Unless they mean at the oil drain tube or the oil feed tube. Either of those are replacement parts or orings. An entire new turbo shouldn't be needed just to fix this I wouldn't think.
Regarding the FICM. I wouldn't have installed the stock one again. Did they give you a reason? Did they say the voltage was out of spec? The after market 58v units are the goto solution to the FICM problems.
Have you done the 'blue spring' update yet? You probably have, but if not I would get that installed.
Seattle60 is offline
post #6 of 6 Old 07-01-2014, 11:11 AM
Heavy_GD's Avatar
unfortunately not
GD
Heavy_GD is offline
