few questions about degas bottle - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-28-2014, 09:42 PM Thread Starter
Ok guys gotta a few questions about the degas bottle on my 6.0
1. Is it ok to let pressure off of the system when hot?
2. Why does my 6.0 and my friend's 6.0 have more pressure on the cap when the trucks are tuned vs when they are on stock tuning?,
Mines an 03 his is an 04. Both stock bolts, I have a sct Livewire with custom Looney tune, he has a superchips flashpaq.
Thanks guys
HardcoreFx4 is offline
post #2 of 8 Old 06-29-2014, 06:38 AM
Quoted: 58 Post(s)
Thanks guys
1). Yes, but be careful not to get burned.
2). Tuned motors produce more heat, have more boost, and have increased cylinder pressures. Increased heat equals higher pressure in a sealed system (of course until the cap vents). Increased boost and cylinder pressure is what your head gaskets are trying to contain and keep out of the cooling system. When my head gaskets let go (under a high load, high boost situation) I would get up to 22 psi in my cooking system. Cooling system pressure did not match boost pressure, but they moved upward together. After studs, o-ringed heads, full Bulletproofing, I now monitor cooling system psi. Normally is 8 to 9 psi, far below the 16 psi vent pressure of the cap.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 8 Old 06-29-2014, 07:11 AM Thread Starter
Ok so what your saying is it's normal to have more pressure, someone said since I have a custom tune, the writer makes it not have as high of cylinder pressure. Is that true?
post #4 of 8 Old 06-29-2014, 07:20 AM
ZMANN's Avatar
Quoted: 1672 Post(s)
the writer wouldn't be very popular if He did that
he would have to limit boost and fuel like an Eco tune
We Miss you Ronnie
ZMANN is offline
post #5 of 8 Old 06-29-2014, 07:21 AM Thread Starter
Well they said they are safe for stock bolts.
post #6 of 8 Old 06-29-2014, 07:23 AM
ZMANN's Avatar
it may be?
so if it was less than stock it would be under performing the stock tune
We Miss you Ronnie
ZMANN is offline
post #7 of 8 Old 06-29-2014, 07:25 AM Thread Starter
it may be?
Yeah that makes since. Thanks.
post #8 of 8 Old 06-29-2014, 07:32 AM Thread Starter
If I keep the cap loose on my truck will it leave a lot of the pressure off the system?
