Need some ICP/HPOP advice. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-28-2014, 11:51 AM Thread Starter
So my truck died on the way home a few days ago. Lost power just puttering down a country road. Had to walk home with my 2 year old son.
The truck is a basically stock '04 6.0. It has a river city egr cooler bypass and the sct mild [mileage] tune. The stock head gaskets are still holding at 220k.
Codes are P0676, P2285, P2290, and P2291. Had to borrow a snap-on scanner from a friend of a friend because the Autozone scanner wouldn't read anything.
So anyway, based on googling those codes, I replaced the ICP sensor and the glow plug module. Still nothing. The truck will not start with the sensor unplugged either.
What's next? HPOP? Any wise counsel is appreciated..
Thanks, RTP
ralphtheplumber is offline
post #2 of 15 Old 06-28-2014, 12:57 PM
F350Powerstroker's Avatar
If it's not starting at all I would say HPOP however if it it running but like crap almost like it's missing and it could be a bad IPR valve. Had mine do that.
~1973 F250 Highboy
~2003 F350 Super Duty XLT FX4 6.0 Powerstroke
4.56 Yukon Gears,Detroit Locker,37x13.5x17 Interco Super Swamper M16,8in Custom Lift,Bilstein 5125 Custom Valved Shocks (Triple Front/Dual Rear),Fabtech Dual Rear Shock Kit/Traction Bars,ARP Head Studs, Sinister Headers/Y Pipe/Regulated Return,175 cc Injectors,Edge Juice Platinum with Attitude,SCT Tunes,Snow Performance Stage 3 Water Methanol Injection,FASS 150/180,Banks Techni-cooler System,Fluidampr,4in Straight Pipes.
F350Powerstroker is offline
post #3 of 15 Old 06-28-2014, 01:17 PM
j.mo's Avatar
Quoted: 1935 Post(s)
Not to thread jack here.
But are you saying if one were to have a bad ICP, unplugging it and starting the truck should tell you?
I'm having an issue with a truck I have, 06, that starts perfectly fine when cold. But once up to temp will not start if you shut it down.
So in theory, I could find out if it is an Icp problem, if after unplugging the Icp the truck starts fine?
My neighbor drives a Prius.
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.mo is online now
post #4 of 15 Old 06-28-2014, 01:32 PM
Do you still have the stock STC fitting?
Seattle60 is offline
post #5 of 15 Old 06-28-2014, 01:58 PM Thread Starter
I thought those were only on the '05 and up?
Build date inside the door is 01/04. It says "2004" right on the valve cover. I didn't think I had an STC fitting?
However, my ICP sensor is on the valve cover, which I've been told that they didn't start doing until around 06/04, so who knows? I was pretty happy that it wasn't behind the turbo where it was allegedly supposed to be.
post #6 of 15 Old 06-28-2014, 04:19 PM
My apologies, you are correct. Your pump probably looks like this: See page 41, http://www.powerstrokediesel.com/docs/EF_456.pdf which is for the 2003.25
post #7 of 15 Old 06-30-2014, 07:56 PM Thread Starter
Yes. Also, it's a really easy thing to check. It takes 10 seconds to pop the hood and unplug the sensor.
post #8 of 15 Old 06-30-2014, 09:09 PM
snowmakerdrew's Avatar
Thanks, RTP
Do you have a monitor you can hook up to it to see ICP pressure and or voltage, IPR % and or voltage? FICM sync etc? This will give you a better indication of whats going on.
snowmakerdrew is offline
post #9 of 15 Old 06-30-2014, 10:46 PM Thread Starter
I think that I can check some or all of those with my tuner. I had kinda forgotten that I had that. Probably didn't need to burn a favor borrowing the fancy scanner.
I'll plug it in hopefully tomorrow and report back. The truck is currently in my pole barn way in the backyard, and it's pouring rain right now. Also, it's after midnight.
post #10 of 15 Old 07-06-2014, 02:55 PM Thread Starter
ICP pressure = 615 psi, although it took ~10 seconds of cranking to get there.
IPR % = 85
FICM SYNC = Yes
