HELP! Turbo?Y Pipe? Air Filter Howling and Squeal? CAN'T FIGURE OUT!!! - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 Old 06-27-2014, 07:45 PM Thread Starter
F350Powerstroker's Avatar
Angry HELP! Turbo?Y Pipe? Air Filter Howling and Squeal? CAN'T FIGURE OUT!!!
For the life of me I can't figure out what exactly is causing this issue! 189,000 miles and have been wrenching on it almost all those miles so I know the ins and out of this motor pretty well, hopefully someone is familiar and can help!
First, the best way to describe the sound coming from the intake is like a big rig taking off from a stop. Moving a lot of air and in low gear. It gets louder when you push the pedal down (in drive down the road or parked). When driving it will make that heavy sucking of air howling sound and then if I really put the pedal down and hold it, it will make a constant squeal sound. And other times I will press the pedal down and release fast and it will do a short squeal. Other times while this is occurring it will do a slight squeal when it shifts gears. Same goes for in park. It sounds like I am stuck in granny gear. I watch the shifts on the trans and its shifting 1-5 fluid also...When this happens there is no smoke visible at the tailpipe.
After this happened I took the turbo apart and cleaned it (Original 2003 Stock Garret Turbo). Looked pretty good for 189K. Cleaned it according to procedure and everything was very fluid and zero play in and out on the impeller just the usual slight play laterally that gets taken up with oil when running. Veins functioning very smoothly. Cleaned CAC boots, Air Intake Filter, MAF sensor. Reinstalled and sprayed boots just to double check for leaks = nothing. All piping attached well. Took it for a ride (cool - night time) and got on it hard on the interstate, no problems thought it was fixed.
Next Day I went into town and turn the AC on (morning - warm). About 30 min into the trip stopped at a light, when I continued the whoosh/howl and intermittent squeal returned. Continued for some time and then after some traveling it just stopped and was fine. Then right before I got back home it happened again. When inside let it cool down for a couple hours, returned, started, and same problem was there....
After close inspection I don't see any soot near any parts of the Y pipe or flex areas. The only soot I see it on the block near the exhaust manifolds (needs new gaskets). Even tried messing around with the AC to see if it is the compressor causing drag, its is turning on and off correctly. Its seems to happen with AC on or off but IT is the only thing that I haven't used much prior to this problem, could be coincidence. Only other thing on the truck of issue right now is a power steering pump makes a noise on hard turn. Probably irrelevant but you never know with these things!
What I really don't understand is if it was the Turbo or Y pipe wouldn't you think it would be an all the time occurrence. Because when it goes away it runs great. I did notice my max PSI was about 25 though. I can't really compare to what I usually has been because I usually monitor other things more closely.
Any help,suggestions, ideas would be much appreciated! Thanks
~1973 F250 Highboy
~2003 F350 Super Duty XLT FX4 6.0 Powerstroke
4.56 Yukon Gears,Detroit Locker,37x13.5x17 Interco Super Swamper M16,8in Custom Lift,Bilstein 5125 Custom Valved Shocks (Triple Front/Dual Rear),Fabtech Dual Rear Shock Kit/Traction Bars,ARP Head Studs, Sinister Headers/Y Pipe/Regulated Return,175 cc Injectors,Edge Juice Platinum with Attitude,SCT Tunes,Snow Performance Stage 3 Water Methanol Injection,FASS 150/180,Banks Techni-cooler System,Fluidampr,4in Straight Pipes.
F350Powerstroker is offline
post #2 of 12 Old 06-27-2014, 08:04 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im wondering if maybe you have a small crack in one of the bellows on your Y pipes. I have read that this will give you the high pitch squeal.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 12 Old 06-27-2014, 09:21 PM Thread Starter
Yeah I watched a few youtube videos of cracked Y pipes...some are not even close but one is pretty similar maybe its just very small and is intermittent because it can close itself off based on where the torque of the motor moves it? I'd be fine if it was because I'm interested in the sinister Y pipe and headers. But I don't like to just shotgun parts and especially if it's something else like the turbo.
~1973 F250 Highboy
post #4 of 12 Old 06-28-2014, 12:07 AM
Quoted: 37 Post(s)
Exhaust leaks can do that, especially at the manifolds.
Sure you aren't just hearing the fan lock in? Maybe a worn belt also.
Heavy_GD likes this.
1994 F350 7.3 PSD 4X4 ZF5 DUALLY
PHP HYDRA, 6637, 3-4 DP TO STRAIGHT 4 BEHIND THE TIRE, 1.0 EXHAUST HOUSING, DIY D66 TURBO, FUGA E-FUEL, EBPV DELETE. Cooper discoverer AT/3'S.
2010 VW JETTA TDI DSG Kerma tune. Hankook ventus v2 concept 2.
79jasper is offline
post #5 of 12 Old 06-28-2014, 04:08 AM Thread Starter
If it's the fan locking in its not on a good way but makes sense I'll have to pay closer attention to the fan itself, it's just seems distinctively coming from the air system...and the belt has about only 2000 miles on it (Motorcraft).
~1973 F250 Highboy
post #6 of 12 Old 06-28-2014, 05:43 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive got a fairly new belt on mine that likes to squeal. Very high pitch metal to metal type squeal. I finally took some belt dressing to it. Worked instantly.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 12 Old 06-28-2014, 10:27 AM Thread Starter
It's not a belt squeal, or pulley for that matter they are areal newer. Hopefully hear from some that have had cracked y pipes I'm thinking that's what it is....
~1973 F250 Highboy
post #8 of 12 Old 06-29-2014, 11:03 AM Thread Starter
Anybody else have any input?
~1973 F250 Highboy
post #9 of 12 Old 07-01-2014, 01:37 PM
Blown F-150's Avatar
I would also guess at the cracked bellows being suspect. Mine made a heck of a high-pitch squeal/whine about half the time. I was able to get under the truck and look up with a flashlight to see some soot around the bellows. I had a new flex pipe welded in (replacing the OEM bellows) by a decent exhaust shop and the noise went away.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #10 of 12 Old 07-02-2014, 11:38 AM
Soledad's Avatar
Garage
In my opinion a loud 'roaring' or 'whooooosh' sound like you hear on the big rigs would indicate to me that the fan clutch may be locking in.
A siren like or howling 'woooooo' sound can indicate a leak in the bellows, up-pipe/y-pipe/down pipe connection, exhaust manifolds or in one instance that I read about, a coked up bearing in the turbo (new bearing was required). In another instance the persons problem was a loose up-pipe/y-pipe connection causing some gasket to act like a reed and make the sound.
The tea kettle high pitched sound can be leaking up-pipe/y-pipe bellows or connections, leaky exhaust manifold, leaky CAC or CAC boots or leaky degas cap.
A squeal could be the turbo or leaky up-pipe/y-pipe bellows. Could be squeaky belt, tensioner pulleys, alternator, A/C pump and etc etc.
To test for the exhaust leaks, (you'd want to do this at night and on a cold engine) you could have someone place their foot over the exhaust pipe or restrict it somehow, then have someone start the truck while you are under the hood with a flashlight looking for smoke. Or you can get a long 3/8" or 1/2" rubber hose and use it as a type of stethoscope to listen for air leaks (it's pretty apparent when you find a leak). Or you could make a boost leak and exhaust leak detector and pump each system full of air. Or, you could place aluminum foil around the bellows to see if they soot up over a week or so.
Just my $.02
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
The Following User Says Thank You to Soledad For This Useful Post:
Ack (08-12-2014)
