6.0 head studs cab on install questions. - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 21 Old 06-27-2014, 05:34 AM Thread Starter
Am I reading correctly?
Can I do head studs in my driveway? I'm reading it's possible by tilting the engine some.
I'd really appreciate advice from someone that has done this without removing the cab.
Thanks for all the help.
Damon
DetroitLeaker is offline
post #2 of 21 Old 06-27-2014, 05:37 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
I've done 10
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #3 of 21 Old 06-27-2014, 06:15 AM
Gadgetguru's Avatar
Quoted: 445 Post(s)
Garage
Damon
Yes, you can do it in your driveway and no need to tilt the engine. Lots of threads and stickies available on this. Here is mine: And so it begins... the build . Do a bunch of reading and research and then ask your specific questions. We're here to help along the way.
john galt and Nathanward71 like this.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #4 of 21 Old 06-27-2014, 06:23 AM Thread Starter
awesome...
Thanks for the link to your build.
Damon
post #5 of 21 Old 06-27-2014, 09:56 AM
This article talks about doing them in cab. Ford Super Duty: Project Outcast Part 2 - Diesel Power Magazine
I'm like you, where I need to do mine as well soon. I was ready to build a cab lift so I could perform the procedure cab off, but after a lot (probably 20hrs) of reading and researching, I've decided to do it cab on.
There is another forum that has a doc of tricks. I will try to find a link to it. (Mods sorry if that is not proper procedure)
Seattle60 is offline
post #6 of 21 Old 06-27-2014, 09:59 AM
Here is the tips doc I was talking about. (again it's from a different forum - which I do not belong to, the same or better info may be found on this forum) Hope that helps.
http://www.ford-trucks.com/ford-manu...rvice_Tips.pdf
post #7 of 21 Old 06-27-2014, 10:55 AM
dnf12908's Avatar
Quoted: 31 Post(s)
Here's a link to mine as well.
Starting my build now, too...
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #8 of 21 Old 10-12-2014, 04:42 PM
Heard some are doing it one bolt at a time with good head gaskets. Is this possible?
Jd1a is offline
post #9 of 21 Old 10-13-2014, 07:38 AM Thread Starter
Just pull the motor out of the front of the truck.
I'm not a mechanic and it took me 4 weekends to do it.. working a little bit each weekend.
I'm 180 pounds.. and torqueing studs to 250 foot pounds was challenging for sure. had to basically put my legs against the block and pull with all my might smoothly to get the torque wrench to click.
I couldnt' imaging trying to torque it to 250 with the block in the cab.
She runs like a champ now.. you can really tell how much better it runs than my dads 6.0.. he wants studs and a tuner on his now.. haha
Damon
post #10 of 21 Old 10-13-2014, 01:11 PM
Damon
Hey Damon, What type of torque wrench were you using?
