One more EOT thread... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-26-2014, 04:00 PM Thread Starter
Arrow One more EOT thread...
Long time lurker....first time I've had to post.
First off I'd like to thank the community on this site for all of the great information I've recceived. Injectors, HPOP's EGR deletes, fueling issues, cooling issues, and all of the other little 6.0 problems that arise have all been much easier with the information contained here.
Now onto my current issue, the truck is a 2007 F350 KR. 98K miles on the clock and for the past 30K has had chronic ECT/EOT issues. Mechanics have previously replaced the oil cooler and EGR cooler 3 times (All three times VC-9 was used) all three times the ECT/EOT have remained high after the replacement.
The truck is mostly used pulling a little 6000lb tandem axle trailer, and on long hills it would overheat and puke. Even on flat ground it would almost always throw a wrench.
Here is where I come in, I pulled the truck apart. EGR delete, 4th Oil cooler, SCT livewire (so I actually have accurate ECT/EOT values now), Coolant filter, thermostat, and Oil cooler bypass valve were installed. Coolant system was flushed before the new cooler went in with water for an entire day, followed by restore and restore+( I did not mix them ) and a final flushing. I took the old oil cooler and ran 1 gallon of water through it in reverse out of curiousity and got lots of iron scale.
Now the ECT is great 188-198 (it was 100 degrees outside today and the ECT breached 200 for a few moments then settled back down to 196) but the EOT is still hanging out at 220-240. I even saw a 50 degree delta T yesterday (ECT 190/EOT 240) cruising at 75mph.
I am at a loss at this point, I do not know what step to take next. Any input would be greatly appreciated.
dysphagia is offline
post #2 of 6 Old 06-26-2014, 08:38 PM
You may have a bad oil sensor. Try shooting the pan with a infared temp gun and see if your oil really is that hot.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 06-27-2014, 08:51 AM
I'm curios what the EOT is when you cold start? for example, this morning when I started my truck, it was 59deg ambient temp outside and the ECT and EOT were 80deg.
Seattle60 is offline
post #4 of 6 Old 06-27-2014, 10:16 AM Thread Starter
ECT and EOT start at the same temp when cold 80 degrees, the EOT sometimes starts at 79 or 81 but ECT always starts at 80.
I also shot the top of the oil cooler cover with a IR thermometer and it read exactly what the EOT reading was.
post #5 of 6 Old 08-05-2014, 05:39 PM Thread Starter
Just a little update for everyone. After seeing EOT's of 260 I tore it down and put another ford oil cooler in it. Only got ~60 miles on it today but EOT's never exceeded 207 and delta T was never more than 8 degrees. Taking the trailer out about 250 miles tomorrow for a more stressful test. At least unloaded, the 5th oil cooler seems to have cured the issue.
post #6 of 6 Old 08-05-2014, 06:16 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Good to hear and I'm hoping that does the trick but sounds like your coolers like to clog. 5 oil coolers? That's a new record. Oh and I at your comment of delta T. It reminded me of my Navy days.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
