6.0 headgasket blown...what else should should i get done - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-25-2014, 07:08 PM Thread Starter
Dropped off my 2006 f350 6.0 diesel srw at ford because it was over heating and going through coolant
they diagnosed it as a blown head gasket
is there anything else I should get them to do while they have it apart?
it has 192,000 kms (119,000 miles) and is a rig welding truck...work in northern alberta (-40 in winter)
thanks guys
crbpressure is offline
post #2 of 4 Old 06-25-2014, 07:55 PM
livermore6.02005's Avatar
Oil cooler, bullet proof egr cooler and stc upgrade on hpop. The ford dealership should install the bullet proof egr cooler if you supply
livermore6.02005 is offline
post #3 of 4 Old 06-25-2014, 08:04 PM
Updated STC, stand pipes and dummy plugs, updated turbo supply and return lines, check the seals on the injectors and the o-rings inside the oil rail, make sure your coolant cap is a true 16 PSI one because this could have caused your head gasket to go in the first place, blue spring upgrade.
vashaman01 is offline
post #4 of 4 Old 06-25-2014, 11:32 PM
PlatinumDiesel's Avatar
Id ask how much for new roller lifters
Sent from AutoGuide.com App
PlatinumDiesel is offline
Tags
head gaskets 6.0 , headgasket
