2005 6.0 boot at the turbo - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 15 Old 06-24-2014, 06:21 PM Thread Starter
Has anyone had a problem with the stock blue boot at the turbo blowing off? I have a 2005 6.0, arp head bolts, bullet proof erg cooler, super chip programmer on tow safe mode. About 1 1/2 years ago,towing my toy box up to Oregon it blew it off about 10 times in a 50 mile pull. Replaced boot and both clamps, cleaned turbo and intake tube. 1 1/2 years later hooked to the horse trailer(9600# empty) just cruising at 65 it blew off again(@17lbs boost looking at the edge cts). Anybody have this problem or is this just a service item?
Thanks for any help.
phatm38 is offline
post #2 of 15 Old 06-24-2014, 06:52 PM
ThreeFitty's Avatar
Buddy blew his off in his 06 towing their camper up a hill in VT and it was just stock then. Not a service item it just happens under heavy engine load I suppose
e99 F350 SRW 4x4 RCLB 7.3 Diesel (3/98)
-5" Diamond Eye Exhaust, straight piped
-RiffRaff 6637
-Sinister Diesel Coolant Filtration
-Hopefully a tune soon
ThreeFitty is offline
post #3 of 15 Old 06-24-2014, 07:07 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Clean boots with dawn dish soap. Clean all other parts with brake clean. Right before assembly spray the inside of your boots with hair spray and assemble.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 15 Old 06-24-2014, 07:08 PM
shenanigans
junior125's Avatar
Quoted: 1451 Post(s)
Garage
if it is a blue boot you can RTV it but that requires the truck to sit for 24 hours
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #5 of 15 Old 06-25-2014, 05:59 AM
lx_2nv's Avatar
i replaced my boot with one off amazon
Tom Brown
2004 Ford SEXcursion Limited 6.0
1991 Ford Mustang LX 5.0
lx_2nv is offline
post #6 of 15 Old 06-25-2014, 06:59 AM
Heavy_GD's Avatar
Quoted: 1333 Post(s)
Feedback Score: 3 reviews
Get this and never look back
http://www.dieselperformance.com/ind...uct/index/178P
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #7 of 15 Old 06-25-2014, 07:06 AM
ZMANN's Avatar
Quoted: 1355 Post(s)
Those look nice Heavy GD
Myself I likely make more boost than the OP and have never spit a boot
I just replaced the stockers with new OEM boots and clamps at 100,000 miles as PM Items
ps if your doing new boots and have the plastic driver side tube order the steel tube for the o3 6.0 and it comes with new boots and 2 clamps IIRC all for about 140 then new boots for the pass side '
I don't see how the beans kit doesn't mention u need a steel CAC tube with their kit or doesn't seperate the years since the 04 up uses the plastic cac tube as 1 of the boots ??
Heavy_GD likes this.
We Miss you Ronnie
ZMANN is offline
post #8 of 15 Old 06-25-2014, 07:17 AM
Heavy_GD's Avatar
I blew the turbo boot once and hair sprayed it back on... a few months later I noticed that I couldn't maintain boost while cruising (it would jump/surge 2-3psi) so I pulled all the boots and went to those with a home made clamp that holds the turbo pipe at the alternator... same idea as this:
BD Power - Product: Boot Lock kit
They didnt net any more boost, just steady numbers.
GD
post #9 of 15 Old 06-25-2014, 07:22 AM
Heavy_GD's Avatar
Originally Posted by ZMANN View Post
I don't see how the beans kit doesn't mention u need a steel CAC tube with their kit or doesn't separate the years since the 04 up uses the plastic cac tube as 1 of the boots ??
I changed the link to go straight to the BD site (the beans site is slow), anyway my kit came with a pipe that I didnt end up using.
The instructions list is as a separate part number.
http://www.dieselperformance.com/pro...lamp_Kit_2.pdf
So I suppose they will send the pipe with the kit when you order.
ZMANN likes this.
GD
post #10 of 15 Old 06-25-2014, 07:44 AM
ZMANN's Avatar
Thanks
still confused LOL
I had bought my steel pipe and then when it came with new boots it
opted me out of buying a boot kit since I had the New driver side boots
so I stuck with OEM if the BD site was more clear on what you get for that price I would definitely have tried that
We Miss you Ronnie
ZMANN is offline
