fuel issue sound???? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-23-2014, 04:47 PM Thread Starter
any idea what this could be? starts fine. accel fine and power fine.
mods are blue spring, egr delete and cat and muffler delete with 4 in downpipe.
just noticed the sound today
click the youtube viedo below...only 30 seconds long
it stops once the fuel pump is down priming
IMG 2406 - YouTube
R1-like is offline
post #2 of 7 Old 06-25-2014, 01:36 PM
What's you fuel gauge reading at? It almost sounds like there is no fluild and the pump is just running dry. That's the only thing I can think of, I've head this sound when my truck was out of deisel after working on it and I just had KOEO. Pump sounded exactly like that.
vashaman01 is offline
post #3 of 7 Old 06-25-2014, 01:42 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 370 Post(s)
Id open the regulator back up and check the orings. Did you only put a spring in it or did you replace all the pieces.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 7 Old 06-25-2014, 05:04 PM Thread Starter
It reads normal I would have to say. It runs fine. I replaced the seals along with the spring. I think I might have forgotten to replace the collet oring now that I think about it. But there aren't any leaks or anything.
R1-like is offline
post #5 of 7 Old 06-25-2014, 05:08 PM
LoxDiesel's Avatar
Quoted: 370 Post(s)
Open it up and take a peek
@loxdce
post #6 of 7 Old 06-25-2014, 05:11 PM Thread Starter
I will tomorrow. Gotta wake up early and my truck don't fit in the garage. It is fine to prime to pump the the fuel filter off? The one on top. To make sure that it isn't priming and not putting fuel into to the bowl... If that makes any sense.
R1-like is offline
post #7 of 7 Old 06-26-2014, 05:23 AM
LoxDiesel's Avatar
Quoted: 370 Post(s)
After everything is reinstalled just cycle the pump 3 times and you'll be fine.
@loxdce
