Need help ordering parts. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-23-2014, 02:23 PM Thread Starter
I'm doing my head gaskets and studs on my 04 f250. While I'm doing it I'm updating a bunch of other stuff. Blue Spring kit, turbo drain, etc...
My build date is Feb/04 I ordered the update kit from MKM customshttp://www.mkmcustoms.com/60powerstrokeupdatekit2003-2004.aspx
but they sent me the wrong one. They sent me the early one so now I have the wrong standpipes. I called them today to get the right stuff coming and told him according to there newer kit 6.0 Powerstroke Update Kit 2005-2007 I needed the STC hpop fitting update kit as well.
He told me that mine might not necessarily have the same hpop. I thought anything with the newer stand pipes had all the same parts..
So do I need the STC hpop fitting update kit as well or not?
Thanks
got2lb is offline
post #2 of 3 Old 06-23-2014, 05:02 PM
I will say the oil feed line for the turbo will not work if you have the early style because the base of it is a threaded connection vise the push in and bolt that they always sell for the upgraded version. Have not found the earlier type upgrade.
Do you have the truck apart already or trying to get the parts before hand.
Quint is offline
post #3 of 3 Old 06-23-2014, 05:51 PM Thread Starter
I know I need the newer style stand pipe. The one they sent me is threaded and mine isn't. They're going to send me the right one. If you look at the kit I linked above for the 2005-2007 there's an hpop update kit. Is that the same for all of the trucks that have the newer style stand pipe?
I have one side of my truck done. Head gaskets and studded. New oil cooler is in. Went to put stand pipe and dummy plugs in and they were different.
got2lb is offline
