turbo issue - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By twoicebergs
post #1 of 7 Old 06-22-2014, 11:23 PM Thread Starter
deputybrandon's Avatar
turbo issue
Anybody seen anything like this? Truck has been running ok but i got a low boost code. I pulled the tutbo hoping to clean it but it didnt workout that way.
ID:	302961   Click image for larger version
deputybrandon is offline
post #2 of 7 Old 06-22-2014, 11:41 PM
john galt's Avatar
Quoted: 1095 Post(s)
I have seen that recently even in another thread.
there are a number of turbo gurus here.
perhaps we can get one to share from their wealth of knowledge.
looks like time for a billet wheel to me
I will see if I can locate the other thread I saw a similar turbo on and
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 7 Old 06-22-2014, 11:44 PM Thread Starter
Great i just ordered a new Garrett powermax. I just hope i dont have anything elsei am missing.
post #4 of 7 Old 06-23-2014, 12:20 AM
john galt's Avatar
I am replacing mine with an MTW stage two in fact I am off to pick up the install kit in the morning.
I would look into rebuilding that one myself just for the experience if I had a "spare"
I would love to redo one sometime.
I just got too good a deal on my upgrade to worry about doing it myself.
I will keep looking later but I cant seem to find the thread with the chewed up wheel and I swear I just saw it within the last month?
if I remember right a bolt got lose and sucked in and chewed up the turbo adn was found in the exhaust in the cat maybe?
post #5 of 7 Old 06-23-2014, 01:02 AM
john galt's Avatar
I did find this from one of the turbo guys on egt's
A slightly chewed up turbine is hard to notice unless you pull and open up the turbo. I have had a few experimental turbos that had this happen. Everything seemed ok except for pretty high egts. I pulled the turbo and the turbine was chewed up.
Here are a couple of mods that will help:
11 blade single plane billet wheel upgrade
Ported intake manifold (number 1 choice)
Upgraded intercooler
Water injection
not sure if that really helps you but?
post #6 of 7 Old 06-23-2014, 01:19 AM Thread Starter
So i will cause higher egts. Any idea what would / could chew it up? I found a post with pics just like mine but no info on cause.
post #7 of 7 Old 06-23-2014, 05:14 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Usually it is a heat issue, but it could be from corrosion and once you loose a piece from vibration, others will follow soon.
john galt likes this.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
