Lifter failure. Engine rebuild - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-22-2014, 05:19 PM Thread Starter
Just had a lifter failure which trashed the engine. Working on a rebuild. Is there anything that you would recommend that I do while the engine is torn apart. Recently put in a PowerMax turbo, new injectors, Head studs and EGR delete, coolant filter. It's a daily driver. Thanks
Bam$bam is offline
post #2 of 3 Old 06-23-2014, 03:52 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
If you are doing the reman yourself, you should have everything machined and put all new parts into it. Don't re-use anything as long as it's a total tear down. Price it all out, we may be competetive with our pricing.
AshevilleEngine.com is offline
post #3 of 3 Old 06-23-2014, 02:20 PM
There is an update kit, depending on year (03-04)(05-07) that includes some updated parts. MKM customs sells them (others may as well). Google "6.0 Powerstroke Update Kit". and select your year. They are between 320-400. Might as well do it now while your engine is in pieces. Sorry for your bad engine. I feel ya.
Seattle60 is offline
