6.0 starts but cranks long runs like crap! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-22-2014, 09:33 AM Thread Starter
Ever since the temp outside started to rise my trucks been cranking longer than normal before starting. Once it starts it runs like crap until it's up to operating temp, seems like it don't wanna shift/ no power just don't run good at all. I'm at a lose of what could be causing this.
2006 F-250SD CCLB Lariat
Egr delete
Blue spring
Livewire ts W/ looney tunes
woody09 is offline
post #2 of 19 Old 06-22-2014, 01:42 PM
Blown F-150's Avatar
You're best off starting with a monitor like a Scan Gauge II so you can check ICP sensor pressure and IPR valve activity.
This way you can help troubleshoot the issue as a HPO system oil leak or if the long cranks and no power have something to do with injectors/FICM.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #3 of 19 Old 06-22-2014, 04:20 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I would go back to stock tune and monitor all your vitals.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 19 Old 06-22-2014, 07:30 PM Thread Starter
Okay blown f150 I will get my brother in laws scann gauge tomorrow what should I be looking for number wise on those? And should I do that running stock like bluedemon6.0 said?
Egr delete
Blue spring
woody09 is offline
post #5 of 19 Old 06-22-2014, 07:36 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 330 Post(s)
Running like crap cold is either injector stiction or weak ficm usually.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #6 of 19 Old 06-22-2014, 07:42 PM
Tunes have caused odd issues for many, you are best off putting it back to stock to troubleshoot.
Lots of good info in the sticky to troubleshoot with, but monitor your FICM voltage, ICP pressure and IPR percent.
This will be a good starting point in figuring out what is going on. It is possible it could be more than one thing like a weak FICM and HPO leak.
2006 F-350
Gryphon FICM tuner
ScanGauge II
Updated STC fitting
post #7 of 19 Old 06-22-2014, 08:39 PM Thread Starter
Do you know if the scan gauge 2 has the icp and ipr as an option? I used it once before I got my livewire to monitor my water temp but that's it.
Egr delete
Blue spring
woody09 is offline
post #8 of 19 Old 06-22-2014, 08:45 PM
Try this link it has every different type of monitor and the pids for the scan gauge. Or you can visit the scan gauge website and look up xgauge there is a list of pids there as well.
To answer your question yes a scan gauge 2 will monitor all your vitals minus fuel pressure and egts.
Write Up: Monitoring the 6.0L PSD.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #9 of 19 Old 06-24-2014, 03:07 PM Thread Starter
Getting the gauge tomorrow took longer than I thought. So will post tomorrow night with my results. Thanks for the help!
Egr delete
Blue spring
woody09 is offline
post #10 of 19 Old 06-24-2014, 03:57 PM
drivininidaho's Avatar
Quoted: 67 Post(s)
Egr delete
Blue spring
Yes it does. I monitor fmp boost ipr and icp on mine. I know my icp is low so im trying to figure out why.
Lyndel
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
