No start - Ford Powerstroke Diesel Forum
post #1 of 54 Old 06-21-2014, 05:50 PM Thread Starter
SAILOR97's Avatar
No start
Ok I got a problem and am not sure what to do...Kind of at a loss..So drove the truck 250 miles and stopped on the way up to go camping to get lunch. When came back out the truck wouldn't start. So I was looking at my CTS Insight and I was only getting 300 PSI for fuel (I know you need 500 to start) well the guy I was with said let's jump it even though it was turning over fine but I said ok. Connected the jumper cables and it started right up. Got to the camp spot started and stopped all weekend no problem starting (this was at least a dozen times) so we get home and stop at a friends house and hang out for a little bit and came out to go home and it did the same thing only getting 300 psi so we hooked up the jumper cables but it didn't fire right off had to leave the cables on for a while and finally fired right off. So I Figured it must be the batteries still scratching my head I bought a new set and installed them and went to start it its still doing the same thing. Now here are my volts with both old and new batteries with the key on engine off 11.6 and with it running (when it was was 13.2 fluctuating down to 13 and once in a while dropping below that) I really don't know what to do. Can any of y'all help me much appreciated
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #2 of 54 Old 06-21-2014, 06:10 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
You've got a HPO leak somewhere.
dhanna6powerstroke is offline
post #3 of 54 Old 06-21-2014, 06:18 PM Thread Starter
SAILOR97's Avatar
You think so dhanna? Man I dont even know where to begin. Not seeing any oil or would I
SAILOR97 is offline
post #4 of 54 Old 06-21-2014, 06:26 PM
Mod Newbie
Quoted: 20 Post(s)
You won't see oil because the HPO system is all internal. Most common are the STC fitting on at the HPOP, dummy plugs or stand pipes.
post #5 of 54 Old 06-21-2014, 06:29 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
High pressure oil is all internal. Have you ever changed the starter in the truck? Every 6.0 starter I've changed has made a dramatic difference in turn over speed. The original starters are different than their replacement. The new starter is a 6.4 starter.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #6 of 54 Old 06-21-2014, 06:33 PM Thread Starter
SAILOR97's Avatar
Well I guess it dont matter about 6 months ago when doing the injectors i replaced the standpipes and dummy plugs with the new updated ones...man this is gonna suck..I'm not sure how to even troubleshoot that. I did notice even after replacing the batteries that fuel pressure didnt build above 190 this time around. Well I can put the old batteries back in and put that 350 bucks towards figuring this out
SAILOR97 is offline
post #7 of 54 Old 06-21-2014, 06:39 PM
Mod Newbie
Quoted: 20 Post(s)
That's not fuel pressure you're reading, that is ICP which is the High Pressure Oil. You could possibly have a bad ICP sensor causing it to give false readings. Next time it does it, unplug your ICP sensor and see if it starts. If it does, replace the sensor. If it doesn't, you'll have to air test the system to find the problem.
post #8 of 54 Old 06-21-2014, 06:54 PM Thread Starter
SAILOR97's Avatar
Oh ok bud thanks for the help...guess I will try that in the afternoon and see if that works. Seriously thanks for the help either way I'm learning more and more about this motor. If it does require an air test I'm gonna have to break down and let someone else test it and pay for the troubleshooting it down to the cause as I still want to fix the cause..lol
SAILOR97 is offline
post #9 of 54 Old 06-22-2014, 02:03 PM Thread Starter
SAILOR97's Avatar
Ok so I got up this morning and before I disconnected the ICP I figured I would see if it wouldn't start. Well it fired right off. So it sat all night does that change anything you think?
SAILOR97 is offline
post #10 of 54 Old 06-22-2014, 02:55 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
What year is your truck? What is your ipr% while cranking?
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
