03 6.0 knocking - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-21-2014, 06:17 AM Thread Starter
03 6.0 knocking
Had the truck and a mechanics and he thinks it sounds like a bent rod. I was thinking injector knock since it sounds similar to what my duramax did when the injectors knocked on it. Truck does shoot a code for injectors #6 & #3 also. I'll try and post a video
Freeboy94 is offline
post #2 of 7 Old 06-21-2014, 07:10 AM
VvPowerStrokevV6.0's Avatar
My 03 did the same thing a nice rod knock sound when I had about half the injectors go bad at once. It also smoked like a train tho. I would think it's injectors on it and since it has injector codes.
VvPowerStrokevV6.0 is offline
post #3 of 7 Old 06-21-2014, 07:16 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 349 Post(s)
03 6.0 knocking
If a rod was bent it would smoke since the cylinder wouldn't be getting the proper compression.
If a bearing was spun. That's another story
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 7 Old 06-23-2014, 04:58 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
You could have a situation in which there is so much fuel in a cylinder that it's trying to compress it causing a knock. I'd remove the glow plugs in those two cylinders and crank it to see if a bunch of fuel blows out. If so, you'll know injectors caused the knock but you then need to cross your fingers and hope that it hasn't bent a rod yet.
AshevilleEngine.com is offline
post #5 of 7 Old 06-23-2014, 05:06 AM
LoxDiesel's Avatar
Quoted: 349 Post(s)
If it was over fueling it would smoke.
@loxdce
post #6 of 7 Old 06-23-2014, 11:48 AM Thread Starter
Still can't figure out how to put a video on YouTube from my phone to post. But it gives me trouble starting in the mornings and gives a damn good size puff of smoke when it finally starts. Also it takes a few seconds to build oil pressure once it is started. Hpop was supposedly replaced less then 10k ago. Not sure if that info helps
post #7 of 7 Old 06-23-2014, 12:00 PM Thread Starter
