weird surge - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-17-2014, 01:38 PM Thread Starter
weird surge
Got a 2006 and it's very sparatic but sometimes while under light accelaration it will surge and rpms go up. It's like you pushed on the throttle more and going faster but my foot is in the same throttle position. and sometimes while sitting at a red light it will idle high or even coasting to a red light it will have a high idle. It will also do it at 70mph with cruise control on. It is very erratic will do it every now and then, it might act up a couple times a day and then be normal for a day or two and then do it again. I pulled the ICP plug and there is no oil on the pigtail and I can't see any damage on the wires. I replaced the accel pedal/TPS asy and no change. My main question is will a ICP go bad even if it's not leaking oil? FICM never goes any lower than 47.5 ICP is good at idle and WOT and so is the IPR. I haven't been able to see a change in the ICP or the IPR when the truck is acting weird, it could be changing but by the time I look up at the scan gauge everything appears normal.
I am the original owner I bought the truck brand new and it has 136,000. At 96,000 I had head gaskets, studs, oil cooler, egr delete, stc fitting, blue spring, coolant filter, 4" straight pipe, and all the other updates done at that time. Also oil has always been changed every 5000miles never more than 6000miles per oil change. Fuel filters are done every 10,000 to 12,000miles.
Truck has been running trouble free for the past 3 years or so. When the truck was under warranty it had FICM replaced twiced, the VGT once, the throttle pedal asy, and had a major oil leak fixed which was the bed plate.
smokejoke is offline
post #2 of 10 Old 06-19-2014, 03:55 PM Thread Starter
post #3 of 10 Old 06-26-2014, 06:17 AM Thread Starter
truck is still doing it.
post #4 of 10 Old 06-28-2014, 09:45 AM
I have the same issue but cant seem to figure out what it is, some times mine also cuts out while driving after it has accelerated out of now where, its quite annoying!! Ive been looking all over the internet and found a few other people with similar problem but haven't really found the solution, but could be caused by ICP and maybe IPR , or even a wire harness. I think Im probably going to try and replace my ICP soon to see if that is the culprit.
f250brah is offline
post #5 of 10 Old 06-28-2014, 03:15 PM
This article talks about Oil problems, and surging is one of the symptoms. Might be a good read unless you have already seen this article. I learned a few things about my own issues from it. Dead in the Water - Oil Problems - Diesel Power Magazine
Seattle60 is offline
post #6 of 10 Old 07-01-2014, 03:18 PM
Ford diesel girl's Avatar
Quoted: 296 Post(s)
Has your truck died when turning at all? I had the same symptoms, and it was my CPS. It would sure at idle mostly, and died on left hand turns. Shut it down, and it restarted just fine. Replaced the CPS and it was fine.
Pinky
'04 F350 Pinky truck
BPD oil cooler system
BPD EGR cooler
BPD FICM
BPD water pump
I work at some place, in a desert, with a tank...
Originally Posted by Evil Eye View Post
Jeffrey, SHUT IT. I might have to ask Christine to give me a hand in smacking you around a little bit.
Ford diesel girl is offline
post #7 of 10 Old 07-01-2014, 07:46 PM
It dies out of no where can be when I'm turning left or right or not turning at all but I will see if that code pops up when I read my dtc thanks for the help and info
f250brah is offline
post #8 of 10 Old 07-02-2014, 07:42 AM
Quoted: 296 Post(s)
Mine had the weird surges as well, but only seemed to die on left hand turns (I had heard a few others had this same symptom, so strange). Good luck!
Pinky
BPD EGR cooler
BPD FICM
BPD water pump
post #9 of 10 Old 01-18-2016, 06:11 PM
dieselfumes's Avatar
I've been looking at all the surge issues on here, and they're all unanswered, and cant belive no one has found the issue, this sucks!
"I refuse to tip toe through life only to arrive safely at death
  • 37's on 22's
  • 8' Fabtech Lift
  • Fox Shocks
  • 4.56 Gears
  • Mag Hitec billet axle covers
  • Mag hitec oversized trans pan
  • Triple disk Torque converter
  • 25K Husky 5th wheel hitch
dieselfumes is offline
post #10 of 10 Old 01-18-2016, 08:57 PM
jdleach0369's Avatar
Quoted: 2 Post(s)
Garage
everyone has told me to change the ICP sensor and ICP pig-tail
2003 F250 142k
4 IN LIFT 35 BFG'S
SCT X4-SRL tune, 4" STRAIGHT PIPED, AFE CAI
OIL/COOLANT BYPASS,BLUE SPRING UPGRADE
Redhead steering
jdleach0369 is offline
