torque app question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-16-2014, 02:07 PM Thread Starter
soliphant's Avatar
torque app question
just out of curiosity i have a edge platinum programmer that runs on the stock setting and i only use it as a monitor, my question is will i damage my truck if i buy an adapter and run the torque app as well since i can only monitor 4 things at a time with my edge?
Scott
04 F350 Lariat Crew
CAI, EGR delete, Edge juice w/attitude, ARP's, 4 in Magnaflow turbo back, high idle, blue spring
soliphant is offline
post #2 of 4 Old 06-17-2014, 07:22 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
It's a hit or miss with the OBDII splitters. The CAN protocol in the PCM usually can only talk to one device at a time, by splitting the signal, it can confuse the PCM and send false readings to the monitor.
IMO, remove the Edge evo, and just use the Torque App. Your Edge Evo don't have to go to waste, you can contact PHP and convert it to a Gryphon Programmer for tuning the FICM or running PCM custom tunes by PHP.
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 4 Old 06-17-2014, 08:49 AM Thread Starter
soliphant's Avatar
yeah tried it yesterday and truck ended up shutting down, how accurate is the torque app? i am a little skeptical about putting faith in a 5$ app. what PID's should i be monitoring with the app other than the obvious temp ones?
Scott
04 F350 Lariat Crew
post #4 of 4 Old 06-17-2014, 12:13 PM
Powerstroke Techie
Lilpooh's Avatar
I don't run Torque app (I use DashBoss for iOS), but haven't heard any bad reports of inaccurate reports.
Normal PIDs to check is EOT,ECT,FICMv every now and then, the other PID's are mostly used for troubleshooting issues when the truck starts to run different. Fuel PSI should also be checked every now and then.
Here is a good read to help you out.
Write Up: Monitoring the 6.0L PSD.
Lilpooh is offline
