Hey guys well my oil feed line is the old school screw in type at the oil cooler cover.
So finally figured out that Apparently you have to get a new oil cooler cover for this updated oil cooler line, which by the way noone supplying the lines seems to mention which is kind of annoying.
Any other options out there. Guess I can order a top from MKM as they seem to be the only ones with them, well maybe tousley.
Has anyone done a fitting arrangement and used a good hydraulic line in place of the stock oil feed line. I was thinking if these would work on our garret turbos (assuming the T4 is for the 7.3 liter guys) T4 Oil Feed Line Adapter [516001000] - $19.99 : Pacific Performance Engineering, Innovations in Diesel Performance.
Then stop by the local hydraulic shop and just have them whip me up a hose real quick.
Could even do a short elbow of solid tubing at the top then go from there.
