Coolant in oil :dunno: - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-15-2014, 10:35 AM Thread Starter
MooreSix0Stroker's Avatar
Garage
Exclamation Coolant in oil :dunno:
Can a failing oil cooler cause coolant in oil?
John
07 F350 cc/sb Fx4 Lariat
ARP studs, OEM
head gaskets, 4" exhaust turbo back 6" tip, egr delete, BPD oil cooler and filtration, sct turner, egde insight monitor, coolant filter, high idle mod, Recon smoked mirror and cab markers
MooreSix0Stroker is offline
post #2 of 7 Old 06-15-2014, 10:43 AM
j.mo's Avatar
Quoted: 1922 Post(s)
Bingo
Edit: I am dyslexic today. Thought you said oil in coolant.
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.mo is online now
The Following User Says Thank You to j.mo For This Useful Post:
MooreSix0Stroker (06-15-2014)
post #3 of 7 Old 06-15-2014, 11:00 AM
DieselTechKid's Avatar
Usually if an oil cooler is leaking internally you will find oil in the cooling system. So, it can possibly be the other way around as well; coolant in the oil. There is a Ford TSB where you replace the oil cooler and egr cooler due to restricted coolant passages in the oil cooler heat exchanger; therefore, causing damage to the egr cooler due to overheating. I see you already have an EGR delete, so I would just consider doing an egr cooler delete also along with replacing the oil cooler. Bullet Proof Diesel has an external oil cooler kit. Another thing is there could be cavitation of the engine front cover behind the coolant pump. Other possible causes are leaking head gaskets or damaged cylinder head.
DieselTechKid is offline
The Following User Says Thank You to DieselTechKid For This Useful Post:
post #4 of 7 Old 06-15-2014, 11:46 AM Thread Starter
Garage
[/QUOTE]Other possible causes are leaking head gaskets or damaged cylinder head.[/QUOTE]
Hope not had hg done last year. Apr studs installed too head checked
John
ARP studs, OEM
post #5 of 7 Old 06-15-2014, 12:10 PM
Hope not had hg done last year. Apr studs installed too head checked[/QUOTE]
I would remove the coolant pump and check the front cover for cavitation. It's the easiest and fastest thing to do as far as tear down and diagnosis goes.
post #6 of 7 Old 06-15-2014, 12:20 PM Thread Starter
Garage
I would remove the coolant pump and check the front cover for cavitation. It's the easiest and fastest thing to do as far as tear down and diagnosis goes.[/QUOTE]
Dumd ? But is the coolant pump same as water pump
John
ARP studs, OEM
post #7 of 7 Old 06-15-2014, 12:25 PM
Dumd ? But is the coolant pump same as water pump[/QUOTE]
It sure is! ha
