03 6.0 long crank when WARM not hot. - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-12-2014, 06:59 PM Thread Starter
Sorry its kinda a long post but please bear with me. I have a 2003 F250 with 87k miles. About two weeks ago it started to crank for a 8-10 sec before starting when warm which isent normal for my truck usually it starts within 1-2 seconds. I use a scan gauge 2 and ive only noticed it doing it between 130-160f when the glow plug light goes on and off with in a couple seconds. However it is intermittent and will not do it when it is hot 160-180 or cold when the glow plugs are active. The ipr icp fmp are all good while cranking.
The FICM was replaced 5 months ago along with the oil cooler and egr cooler (which has sence been deleted). About a month ago i lost the right head gasket so i took the cab off studed it while putting it back together i pressure checked the HPO i dident hear any leaks. It has the early style oil rails without the standpipes and dummy plugs instead it has the stainless braided lines with quick disconnects. I changed the IPR and ICP sensor along with the #3 injector (my mistake) put the 6.4 banjo bolts in it deleted the EGR put a fass platinum fuel system on it in updated tubo feed and drain tubes.
Iv seen a couple of forums with people having similar problems some saying HPO leak others saying GPCM or glow plugs which is what im leaning towards.
I personally think it has something to do with the glow plug system because when i go to fire it up in the morning the glow plug light pops on for 5 or so seconds it fires within 1-2 sec and runs like a champ. As soon as its up to temp i can shut it off and it fires right back up every time. it only seems to do it in that 130-160 range idk maby the fuel doesn't want to light cause the glow plugs dont run in that temp range and when its hot its just hot enough to fire i have no clue. Has anyone else had this problem it just seems like know one can figure this one out. any help is appreciated.
cmonarch94 is offline
Tags
glow plug control module , glow plugs , long crank
