Looking to get some opinions on what else should be changed on a motor rebuild for a head gasket/head job at 240k, truck is mainly used for 15-20K+ towing avg 1000-1500miles a week so its definitely used to its limits.
I want to to do this rebuild right, looking to get at least another 100-150k+ of towing from this, so I am just seeing if I missed anything in the parts lists below for this build. And should I be worried about reusing the block after having a headgasket failure?
Cylinder Heads / 2 / 3C3Z 6049 DA or 3C3Z-6049-ARM
ARP Head Stud Kit / ARP 250-4202
18mm Dowel Headgaskets OEM / 2 / 3C3Z 6051 CB
Warren Diesel / 8 / 175cc (814)-853-0147 PA
Injector O-ring kit / 8 / 3C3Z 9229 AA
Glowplugs / 8 / 4C3Z 12A342 AA
Glowplugs Buss Bar, Right/Left needed /3C3Z 12A690 BA
Both Serpentine Belts
Turbo Mounting Kit / 3C3Z-9T514-AG
Updated Dummy Plugs and Standpipes / 2 / 6E7Z 9A332 B
Exhaust Manifold Gaskets / 2 / 6C3Z 9448 A
BD Diesel Ported Exhaust Manifolds (Drilled Bung) / 2 / BD-1041480
Heat Wrap 2” 100FT
Intake Manifold Gasket Set / 2/ 3C3Z 9439 AA
Intake Manifold Ported
EGR Delete basic ebay kit
OEM Radiator /
OEM Water Pump / 4C3Z 8501 AC
Lower & Upper Radiator Hose
OEM Oil Cooler
OEM Thermostat / 4C4Z 8575 AA
Front engine cover gasket / 4C3Z 6608 B
Front crank seal / 3C3Z-6700-BA
Rear Main Seal / 3C3Z 6701 B
Main/Rod Bearings Set / 3C3Z6D309AA
Cap/bearing for pistons upper/lower / 8
Idler Pulley OEM & Tensioner / 3C3Z 8678 EB / 3C2Z 6B209 AA
Machine Shop labor avg build
Heat Wrap 2” 100FT
OEM Radiator /
OEM Oil Cooler
