I've been chasing oil leaks all over my 6.0 and have one I can't pinpoint.
the oil is running down the block directly below the cam position sensor. Thinking that the sensor o-rings could be the problem, I replaced the whole sensor since my dealer didn't have the o-rings separately. This made no change to the leak.
The leak is a steady drop about every 5-10 seconds. I have a dye kit and light on the way but I figured I would pick your brains while I'm waiting.
Could it be coming from the front cover? I just replaced the oil cooler and it doesn't appear to be leaking, but its hard to see down into front edges of the cooler on that side of the engine. I had one of the big bolts strip that bolt the oil filter housing to the oil cooler but I can see straight down and its not leaking.
Any ideas?
Any ideas?
