Hey all,
Blew these codes last week and did some reading on here which lead me to take out my turbo, replace the unison ring + clean the turbo. Replace the EGR valve, cleaned out the hose from the manifold to the MAP Sensor.... truck ran great for about an hour and once again little to zero boost and the same 3 codes are back. i've check for vacuum leaks and cannot seem to find any...
i'm at a loss here and not sure whatelse to do.:dunno:
2006 F250 SD 6.0L Auto...any suggestions would be great....
Thanks in advance!
Thanks in advance!
