ok guys have issue I hope ya can help with. first off about the truck... 07 f350 studded egr deleted new powermax turbo all 8 reman motorcraft injectors ficm vlt 48.5 deltas <5 degrees icp irp all within spec, all work done about 3,500 mi ago,.. now to the issue. I was running a tune which turns of the cel for the egr delete I put it back to stock and the cel appeared as it should... but the truck runs like poop.. the codes are the 0403 and 0405 for the egr.. now being a 07 and having a engine light on will that cause the truck to run rough.. I still have the egr valve if I need to plug it in and zip tie it :icon_ford:
