I was headed up the road , made a corner. Stepped on the pedal to speed up and it was like someone just shut my fuel off. Got it home codes are telling me it has low IPR psi. ICP was 30 maybe 40 max. I then replaced the stc fitting with the updated version and replaced the screen on the IPR valve ( it had a hole in it). Now it still won't start, oil is up, and now it's reading no ICP. When cranking the "normal" oil psi does come up. The truck is stalk and has a little over 230,000 miles on it, its a 2006 manual transmission.What should I look at next? And should I replace the ipr valve?
Pulled the ICP had oil come out. Kind of a slow dribble. It's still not showing ICP. I'm going to get a new ipr today and might as well do the dummy plugs while I'm at it.
For the pressure it should be running no it was not a lot of oil. It just oozed out. Plugged it back in. It's still not reading any ICP just stays at 0
The HPOP wont have any damage if the screen is broken, well, i think...
Most of the cases i've seen with the iron HPOP's are the bearing on the shaft going bad, eating the HPOP core.
The aluminum ones just stop pumping, they stop building pressure, or sometimes they... i don't know the word in english, they broke the shaft in there, and let a lot of aluminum go into the HPO rails.
Yeah I'm going to leave the HPOP alone till it breaks then I'm thinking about putting one in that runs at a higher pressure.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
