I understand that this has something to do with the turbo, but am not quite sure what. does anyone have any idea on what i should be looking for and what the general outcome would be? i just put nearly 2 grand in parts and labor for a ficm and an icp sensor and harness.
I would try a turbo relearn procedure first to see if that fixes it. If you still have the code look for leaks in the up pipes or intercooler boots also look to see if the map sensor is hooked up with no cracks.
That code is not found in the 03 dtc book. The letter code after the numbers didn't come out until after 05.
The po132 code is for a gasser, a o2 sensor code. The 6.0 has no o2 sensors.
thats what i thought, the check engine light is on and staying on though and thats the only code it threw. ive noticed no change in performance either. just been putting a lot of miles on it since i got it back. im gonna check on the map sensor just in case.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
