When I first bought my truck which was about 5 months ago the ac worked, but now it does had the stuff done to. And I popped the hood yesterday and the line that goes to the heater valve and it was melted in half. So I went to autozone and bought a little sleeve to put it back together. I guess the guy that did the delete and oil cooler melted it and shoved it back behind the battery where I found it.
Off hand check that the pressure switch is plugged in and there is no wire problem then look at the wireing and switch at the a/c compressor it self.
You may also want to check the fuzes and the relay.
that line that was melted only gets vacuum when MAX AC is selected and it isn't a big deal that it was unhooked other than some vacuum loss
agreed give it a visual and look for unhooked connectors and listen to see if the compressor is cycling
if the charge is low it will not come on
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
